[GRASS-user] i.segment and i.segment.stats errors
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 8 01:32:31 PDT 2018
On 04/10/18 17:06, Jamille Haarloo wrote:
> i.segment.stats errors:
Please, whenever you report errors, also report the command line used.
> ERROR: Error while executing: 'CREATE TABLE segmstat_tmp_vect_7968 (cat
> int, area double precision, compact_circle double precision, DV2_mean
> double precision, DV2_stddev double precision, DV2_variance double
> precision, DV2_coeff_var double precision, DV2_first_quart double
> precision, DV2_median double precision, DV2_third_quart double
> precision, DV2_perc_90 double precision, DV4_mean double precision,
> DV4_stddev double precision, DV4_variance double precision,
> DV4_coeff_var double precision, DV4_first_quart double precision,
> DV4_median double precision, DV4_third_quart double precision,
> DV4_perc_90 double precision, IDM2_mean double precision, IDM2_stddev
> double precision, IDM2_variance double precision, IDM2_coeff_var double
> precision, IDM2_first_quart double precision, IDM2_median double
> precision, IDM2_third_quart double precision, IDM2_perc_90 double
> precision, IDM4_mean double precision, IDM4_stddev double precision,
> IDM4_variance double precision, IDM4_coeff_var double precision,
> IDM4_first_quart double precision, IDM4_median double precision,
> IDM4_third_quart double precision, IDM4_perc_90 double precision,
> W2_mean double precision, W2_stddev double precision, W2_variance double
> precision, W2_coeff_var double precision, W2_first_quart double
> precision, W2_median double precision, W2_third_quart double precision,
> W2_perc_90 double precision, DV4_mean double precision, DV4_stddev
> double precision, DV4_variance double precision, DV4_coeff_var double
> precision, DV4_first_quart double precision, DV4_median double
> precision, DV4_third_quart double precision, DV4_perc_90 double
> precision, neighbors_count double precision, area_nbrmean double
> precision, area_nbrstddev double precision, compact_circle_nbrmean
> double precision, compact_circle_nbrstddev double precision,
> DV2_mean_nbrmean double precision, DV2_mean_nbrstddev double precision,
> DV2_stddev_nbrmean double precision, DV2_stddev_nbrstddev double
> precision, DV2_variance_nbrmean double precision,
> DV2_variance_nbrstddeGRASS_INFO_ERROR(7020,1):
The DV2 and DV4 maps seem to be there twice and so there are duplicate
column names, leading to a failure in the CREATE TABLE call.
In the call to i.segment.stats, did you maybe add these map names twice
to the 'rasters' parameter by accident ?
Moritz
