[GRASS-user] Running v.surf.tps
Rich Shepard rshepard at appl-ecosys.com
Wed Oct 10 11:19:41 PDT 2018
On Mon, 8 Oct 2018, Rich Shepard wrote:
> The module employed the default 1.5 for thinning, and the default 300M for
> memory. I think I'll give it 16000M for memory and let 'er run.
   I've learned several things running v.surf.tps on precipitation data from
58 reporting stations. Among them are:
   1) Setting cell resolution to 500m, 100m, or 50m makes no difference in
the appearance of the resulting raster map.
   2) While the region is set to a boundary, the output extends beyond that
boundary (see attached map).
   3) I don't know how to interpret the colors: are blues less than yellows?
   All insights into interpreting this output, or modifying the command to
limit output to the region set to the boundary on the map, will help me
better understand how v.surf.tps works.
Rich
Type: image/png
Desc:
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181010/afc9a73b/attachment-0001.png>
