[GRASS-user] How to use r.grow module
Moritz Lennert
mlennert at club.worldonline.be
Fri Oct 12 02:52:43 PDT 2018
Hi Vidura,
On 11/10/18 19:15, Vidura Dantanarayana wrote:
> Hi everyone,
> I'm a new user to grass and can I know how to create a raster map
> containing one cell using r.grow module. I read the manual but could not
> understand any.
r.grow is not meant for creating a map with one cell. It creates a sort
of buffer around non-null cells in an existing raster map.
To create a new raster map with one cell, you have different options
depending on what you have:
- If you have coordinates for the cell, you can use
- r.in.xyz
- v.in.ascii to create a vector point and then v.to.rast to transform
this to raster.
- If you want to digitize the cell interactively, you can use the raster
digitizer (https://grass.osgeo.org/grass74/manuals/wxGUI.rdigit.html)
Whatever you do, make sure you first have a good understanding of the
concept of computational region in GRASS GIS as this will determine the
nature of your raster.
See
https://grass.osgeo.org/grass74/manuals/rasterintro.html
https://grasswiki.osgeo.org/wiki/Computational_region
for general info and
https://grass.osgeo.org/grass74/manuals/g.region.html
for the module allowing to define the region.
Moritz
