[GRASS-user] r.category
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Fri Oct 12 07:24:12 PDT 2018
Hi Frank,
The error message you sent is related to d.legend module, which you may have called from the graphical user interface, more particular the map window, in order to add a legend to a map display.
If you have a visible legend in your map display, double click it in order to change the range parameter. That should fix the error message.
Or do you have other issues as well?
Cheers
Stefan
Sent: fredag 12. oktober 2018 15:17
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>; grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] r.category
Hi Stefan,
Thanks for your reply. But I did not use cat=range option. I only do r.category map=mymap separator=":" rules=rulefic.txt
with rulefic.txt like :
0:none
1:1 to 2
2:1 to 2
3:3 to 4
4:3 to 4
5:5 to 6
Is something missing ?
Thanks
Le 12/10/2018 à 15:02, Stefan Blumentrath a écrit :
Hi Frank,
You need to specify the range option as range=0,8 (instead of range=0-8 as you did).
Cheers
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces at lists.osgeo.org><mailto:grass-user-bounces at lists.osgeo.org> On Behalf Of Frank David
Sent: fredag 12. oktober 2018 14:24
To: grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
Subject: [GRASS-user] r.category
Hello grass users,
I have an error message in the console when I open some rasters with witch I've done a r.category.
"Failed to run command 'd.legend
raster=ZVT_nac_projet_hoht2__BDalti75_a1_8_sum at derval title=nacelle color=white range=0-8 at=5.0,50.0,6.9,9.9 thin=3'. Details:
ERROR: Option <range> must be provided in multiples of 2
You provided 1 item(s): 0-8"
a r.describe display :
* 0.000000-0.031373 0.972549-1.003922 1.976471-2.007843 2.980392-3.011765
3.984314-4.015686 4.956863-4.988235 5.960784-5.992157 6.964706-6.996078
7.968627-8.000000
r.report display :
| 0-0.031373|from
to |
|0.972549-1.003922|from
to |
|1.976471-2.007843|from
to |
|2.980392-3.011765|from
to |
|3.984314-4.015686|from
to |
|4.988235-5.019608|from
to |
|5.992157-6.023529|from
to |
|6.996078-7.027451|from
to |
| 7.968627-8|from
to |
| *|no data
I don't understand what the error message means (in red color in the
console) ?
Thank your for your help !
Frank
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181012/a7b2eb61/attachment-0001.html>
