[GRASS-user] i.segment and i.segment.stats errors
Jamille Haarloo j.r.haarloo at gmail.com
Tue Oct 16 13:20:44 PDT 2018
The csv looks ok, but quite extensive and heavy.
I reinstalled again and tried with less variables, without the coefficient
of variation and without neighborhood statistics. This time without error.
i.segment.stats map=SegW24IDM4DV4 at LUP1 rasters=DV2 at LUP1,DV4 at LUP1,IDM2 at LUP1
,IDM4 at LUP1,W2 at LUP1,W4 at LUP1
raster_statistics=variance,first_quart,median,third_quart,perc_90
area_measures=compact_circle
csvfile=C:\Users\haarlooj\Stats_SegW24IDM4DV4_16okt18
vectormap=vSegW24IDM4DV4 processes=3
Calculating geometry statistics...
Calculating statistics for raster maps...
Creating output vector map...
(Tue Oct 16 16:31:51 2018) Command finished (94 min 7 sec)
On Tue, Oct 16, 2018 at 1:56 PM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 15/10/18 21:00, Jamille Haarloo wrote:
> > I did with neighborhood statistics and vector, and without.
> > with neighb. statistics & with vector
> > i.segment.stats -n --overwrite map=SegW24IDM4DV4 at LUP1
> > rasters=DV2 at LUP1,DV4 at LUP1,IDM2 at LUP1,IDM4 at LUP1,W2 at LUP1,W4 at LUP1
> raster_statistics=mean,stddev,variance,coeff_var,first_quart,median,third_quart,perc_90
> > csvfile=C:\Users\haarlooj\Stats_SegW24IDM4DV4_15okt18
> > Calculating neighborhood statistics...
> > DBMI-SQLite driver error:
> > Error in sqlite3_prepare():
> > near "IDM4_third_qu": syntax error
> > ERROR: Error while executing: 'CREATE TABLE segmstat_tmp_vect_10260 (cat
> > int, compact_circle double precision, DV2_mean double precision,
> > DV2_stddev double precision, DV2_variance double precision,
> > DV2_coeff_var double precision, DV2_first_quart double precision,
> > DV2_median double precision, DV2_third_quart double precision,
> > DV2_perc_90 double precision, DV4_mean double precision, DV4_stddev
> This is not using the new version of i.segment.stats that I committed
> yesterday. I see that the version available at
> https://wingrass.fsv.cvut.cz/grass74/x86_64/addons/latest/ is still the
> one from before my changes.
> Martin, any reason this has not been recreated since ?
> > without neighb. statistics, but with vector
> > (Mon Oct 15 10:54:02 2018)
> > i.segment.stats --overwrite map=SegW24IDM4DV4 at LUP1
> > no such column: nan
> > no such column: nan
> > ERROR: Error while executing: 'INSERT INTO segmstat_tmp_vect_3516 VALUES
> > (1244,
> 1.128379,0.0694444477558136,0,0,0,0.0694444,0.0694444,0.0694444,0.0694444,0,0,0,nan,0,0,0,0,0.53125,0,0,0,0.53125,0.53125,0.53125,0.53125,1,0,0,0,1,1,1,1,3,0,0,0,3,3,3,3,1,0,0,0,1,1,1,1)'
> Hmmm, not sure where this 'nan' comes from. If I see correctly it is
> from a coefficient of variation of DV4 at LUP1 for an object where both the
> mean and the stddev are 0, leading to a zero division.
> I don't know what DV4 is. Is it normal that an object could have mean
> and stddev = 0 ? If yes, then the coefficient of variation might not be
> useful.
> Anyhow, I just committed a fix (r73555) which should normally replace
> this 'nan' by its SQL equivalent 'NULL'.
> > without neighb. statistics & without vector
> > (Mon Oct 15 14:58:40 2018)
> > csvfile=C:\Users\haarlooj\Stats_SegW24IDM4DV4_15okt18b processes=3
> > (Mon Oct 15 15:15:18 2018) Command finished (16 min 38 sec)
> > with neighb. statistics, but without vector
> > (Mon Oct 15 15:32:39 2018)
> > csvfile=C:\Users\haarlooj\Stats_SegW24IDM4DV4_15okt18c processes=3
> > (Mon Oct 15 15:50:25 2018) Command finished (17 min 46 sec)
> These two are normal as your errors are all in the SQL that creates the
> attribute table of the vector. If you do not create a vector map, you
> obvisouly do not get the errors.
> Does the content of the csv file look correct ?
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181016/210bca66/attachment.html>
