[GRASS-user] Import Sentinel2 with timestamp
Margherita Di Leo diregola at gmail.com
Thu Oct 18 02:33:37 PDT 2018
Hi Martin,
On Wed, Oct 17, 2018 at 1:05 PM Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> st 17. 10. 2018 v 13:00 odesílatel Veronica Andreo
> <veroandreo at gmail.com> napsal:
> > I was also answering Madi to see the example at IRSAE course and
> wondering if that example could be somehow integrated into i.sentinel. Big
> +1 for that! :)
> > However, in theory satellite images would only represent a point in
> time, i.e., only start time should be provided. Why giving a one second
> interval? t.register is able to handle only start time.
> yes, this issue needs to be solved. I darkly remember that
> t.rast.mapcalc was failing with point in time data. Period data is
> just an ugly workaround. It needs more investigation. But for sure
> i.sentinel.import should do timestamp as point in time data.
If I can add a wish to be implemented in i.sentinel.import, is that it
could ingest a text file with list of granules (complete of pattern) to
import.  I'm not sure this is already possible..? I guess that the system
you have implemented works well if you use i.sentinel.download, I haven't
used it because we have the images already in house, but the system  to
archive them may be different.
Thanks again
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181018/bf4f3a01/attachment.html>
