[GRASS-user] i.segment and i.segment.stats errors
    Jamille Haarloo
    j.r.haarloo at gmail.com
    Thu Oct 18 04:41:48 PDT 2018
I thought I did a few times, as it also was successful on Tuesday (without
the coefficient of variation and without neighborhood statistics).
After the error from Wed Oct 17 13:55, I reinstalled to be sure and
retried.
Success!! Thanks alot. Now for the next challenge to begin :)
i.segment.stats -n --overwrite map=SegW24IDM4DV4 at LUP1 rasters=DV2 at LUP1
,DV4 at LUP1,IDM2 at LUP1,IDM4 at LUP1,W2 at LUP1,W4 at LUP1
raster_statistics=mean,stddev,variance,coeff_var,first_quart,median,third_quart,perc_90
area_measures=compact_circle
csvfile=C:\Users\haarlooj\nStats_SegW24IDM4DV4_17okt18
vectormap=nvSegW24IDM4DV4 processes=2
Calculating geometry statistics...
Calculating statistics for raster maps...
Calculating neighborhood statistics...
Creating output vector map...
(Wed Oct 17 18:22:33 2018) Command finished (95 min 6 sec)
On Thu, Oct 18, 2018 at 5:12 AM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 17/10/18 19:15, Jamille Haarloo wrote:
> > Yes, I noticed as other modules weren't working either. Stupid..
> > Just got the results with 7.6 and some "nan" values again.
> This shouldn't happen with the current version. Did you reinstall with
> 'g.extension i.segment.stats' ?
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181018/3e85cff6/attachment.html>
