[GRASS-user] select the map that does not match a string
Frank David
frank.david at geophom.fr
Fri Oct 19 02:09:14 PDT 2018
Hello,
I wonder how to filter the select box (with Shift-Ctrl-L) or the data
tab display, to maps do not match with a string. for exemple
"myraster.*^(?!unwanted_string)" should display all maps beginning with
"myraster" and without "unwanted_string"
This does not work. Is there any trick ??
Thank you for your advice
Frank
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181019/19be28cb/attachment.html>
