[GRASS-user] v.to.points doesn't create a point layer?
Mehrdad Varedi varedi at gmail.com
Sat Oct 20 21:37:45 PDT 2018
I was using v.what.rast and I got an error that no point layer was found.
the layer that was passed was created using v.to.points from a vector file.
The v.to.points creates two tables in SQLite and I didn't like it.  I
exported it to a geo package format and then imported it as the point layer
I wanted to see.(is there another way, please let me know)
I tried v.what.rast and I experienced the same error that a point layer
can't be found on both point layers.This is the v.what.rast command that
generates an error:
v.what.rast --verbose map=POM at Mehrdad raster=ABC at Mehrdad column=ABC
The error is:
Reading features from vector map...
No features of type (point) found in vector map <POM at Mehrdad>
questions:
-  Do you know a way that v.to.points creates only one table in SQLite?
- Why I get the error in v.what.rast? I have looked at the POM and it is
really a points layer (it appears like that in GRASS)
Thanks for your help,
Mehrdad
Mehrdad Varedi
ᐧ
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181021/4c88a949/attachment.html>
