[GRASS-user] r.basin error
pelempito
hoyodepelempito at yahoo.com
Mon Oct 22 09:54:21 PDT 2018
Hi.
I tryed to run the r.basin addon for almost 4000 basins. Approximately 10%
of the basins end without the .csv parameters file. Digging deeper into the
command output, I spotted the following error at the end of the log from
r.basin:
File "/home/jr/.grass7/addons/scripts/r.width.funct", line
132, in <module>
sys.exit(main())
85, in main
prc[2,0] , prc[2,1] = findint(kl,0.3) , 0.3
125, in findint
z1, z2, f1, f2 = kl[int(Xf[0])][0], kl[int(Xf[0]-1)][0],
kl[int(Xf[0])][1], kl[int(Xf[0]-1)][1]
TypeError: only length-1 arrays can be converted to Python
scalars
An ERROR occurred running r.basin
Please check for error messages above or try with another pairs of outlet
coordinates
I think that r.basin stops after this error occurs, which may prevent
r.basin from generating the .csv parameter file for a given basin. I
researched a bit about the scalars in Python, and found this post
<https://stackoverflow.com/questions/21687581/typeerror-only-length-1-arrays-can-be-converted-to-python-scalars-while-trying>
(sorry for cross referencing), which refers that "non-numpy functions ...
don't play nicely with numpy arrays", but I couldn't make more follow up.
The error I just found can be reproduced by importing the raster DEM
included in this ZIP file
<http://geografiafisica.org/consigna/visitante/grass/hydrodem.zip> into
GRASS, and running the following command (I have more coordinates for which
r.basin fails as well):
r.basin --overwrite --verbose map=hydrodem prefix=cuenca13
coordinates=335595,2066655 threshold=22 dir=/tmp/tst
The raster is a subset of the tile Entity ID SRTM1N18W071V3, from the SRTM 1
Arc-Second Global DEM, post-treated by myself with the r.hydrodem addon.
I unsuccessfully tried to solve the issue by updating the region with both
the -a flag and the align parameter, since I read in the forum about that
trick as a possible workaround as well.
My GRASS region output is included below:
g.region -p
projection: 1 (UTM)
zone: 19
datum: wgs84
ellipsoid: wgs84
north: 2068530
south: 2017320
west: 314970
east: 353400
nsres: 30
ewres: 30
rows: 1707
cols: 1281
cells: 2186667
And this is the r.info command output for the raster map hydrodem:
r.info map=hydrodem at PERMANENT
| Map: hydrodem at PERMANENT Date: Mon Oct 22 10:04:29 2018
| Mapset: PERMANENT Login of Creator: jr
| DataBase: /home/jr/Documentos/grass/tst
| Title: ( hydrodem )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: DCELL
| Rows: 1707
| Columns: 1281
| Total Cells: 2186667
| Projection: UTM (zone 19)
| N: 2068530 S: 2017320 Res: 30
| E: 353400 W: 314970 Res: 30
| Range of data: min = 0.946 max = 2340.517
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal -e input="/home/jr/Documentos/grass/tst/hydrodem.tif" outp\
| ut="hydrodem" memory=300 offset=0
I appreciate any help. I also would like to thank the developers for this
great addon.
Jose
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
