[GRASS-user] Create_iwave.py script error for template creation -i.atcorr module-reg
Daniel Victoria
daniel.victoria at gmail.com
Wed Oct 24 17:18:25 PDT 2018
I looks like you have a mixed python installation, with some libraries
coming from ArcGIS and others from your grass installation. Not sure that's
a problem but, if it works on Markus M computer, it's worth checking it out.
On Wed, Oct 24, 2018 at 5:08 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Wed, Oct 24, 2018 at 8:28 AM kameswari devi <kams.devi at gmail.com>
> wrote:
> > Please check the file i have used and error received as an
> > attachment.I tried to interpolate using Create_iwave.py script for
> > i.atcorr module but errors are observed. please suggest me thank you
> Using create_iwave.py in GRASS 7.7,
> python create_iwave.py sensors_csv/testint_B131to142.csv
> works fine without errors. Which GRASS version are you using?
> Markus M
> > Regards
> > kameswari devi P
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181024/716d6d2d/attachment.html>
