[GRASS-user] Create_iwave.py script error for template creation -i.atcorr module-reg
Markus Metz
markus.metz.giswork at gmail.com
Wed Oct 24 23:39:14 PDT 2018
On Thu, Oct 25, 2018 at 3:02 AM kameswari devi <kams.devi at gmail.com> wrote:
> Grass6.4.4 Used for this.
If you want to use i.atcorr, you should use GRASS 7.4 or higher because
quite a few bugs have been fixed in the meantime.
Markus M
> On Thu 25 Oct, 2018, 01:38 Markus Metz, <markus.metz.giswork at gmail.com>
wrote:
>> On Wed, Oct 24, 2018 at 8:28 AM kameswari devi <kams.devi at gmail.com>
wrote:
>> > Please check the file i have used and error received as an
>> > attachment.I tried to interpolate using Create_iwave.py script for
>> > i.atcorr module but errors are observed. please suggest me thank you
>> Using create_iwave.py in GRASS 7.7,
>> python create_iwave.py sensors_csv/testint_B131to142.csv
>> works fine without errors. Which GRASS version are you using?
>> Markus M
>> > Regards
>> > kameswari devi P
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181025/410ff9e4/attachment.html>
