[GRASS-user] append data after a v.in.ascii import
Frank David frank.david at geophom.fr
Fri Oct 26 05:17:02 PDT 2018
Hi Stephan,
If I add two vector in a new one with :
v.patch -c input=map1,map2 out=map3
I notice the map3 first cat start at 2 instead of 1, so all cat are
shifted by one. Do you have an idea of the reason ?
If I append my map1 with map2 :
v.patch -c -a input=map2 output=map1 --overwrite it works well
Thank you
Frank
Le 26/10/2018 à 12:01, Stefan Blumentrath a écrit :
> Hi,
> Try:
> v.patch -a
> https://grass.osgeo.org/grass76/manuals/v.patch.html
> (assuming attribute tables are equal).
> Cheers
> Stefan
> -----Original Message-----
> From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Frank David
> Sent: fredag 26. oktober 2018 11:39
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] append data after a v.in.ascii import
> Hello,
> I wonder what is the best way to append a vector map and his attribute data created with v.in.ascii  ?
> Thanks
> Frank
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181026/a9cc4570/attachment.html>
