[GRASS-user] accent encoding with ps.map
Rich Shepard rshepard at appl-ecosys.com
Tue Oct 30 07:38:20 PDT 2018
On Tue, 30 Oct 2018, Frank David wrote:
> I think some point are missing or lack of documentation. I think about
> [read] command, display layer order, language support, unit of position in
> the page (inch/cm), etc. Some improvement would be great, like line
> thickness from column for example, accent support from v.label (??)...
Frank,
   Yes, there is room for improvement in both ps.map and g.gui.psmap. Perhaps
Martin Landa has another undergrad student in need of a degree project. :-)
> g.gui.psmap is great, but difficult to use because it does not support
> complex document.
   So far my use of g.gui.psmap has been fairly simple and I like that I can
place objects more easily than by changing coordinates in the .psmap file
and recompiling.
   Both ps.map and g.gui.psmap are very useful and for many purposes
(including mine) are more practical than using a different application such
as qgis.
Regards,
Rich
