[GRASS-user] zonal statistics for multiple areas
    Alessandro Sebastiani
    alessandro.sebastiani at uniroma1.it
    Wed Oct 31 02:59:13 PDT 2018
Dear all, i was able to compute zonal statistics for multiple areas using
this script. I used
> import grass.script as gscript
> v_list = gscript.read_command("g.list" , type =
"vect").strip().split("\n")
# i have 5 vectors in my list
> method = ("sum" , "average")
> for v in v_list:
 >    gscript.run_command("v.rast.stats", map_=v, raster = "LC1",
column_prefix = "LC1", method = methods)
Now i have like 4 rasters that i would like to use as input to compute my
statistics. Is there a way to loop this process for rasters and vector at
the same time? i tried creating a list for rasters and using the name list
as raster input but it seems not to work! cheers, Alessandro
Il giorno mar 30 ott 2018 alle ore 11:52 Alessandro Sebastiani <
alessandro.sebastiani at uniroma1.it> ha scritto:
> Thanks a lot for your help!
> Il giorno mar 30 ott 2018 alle ore 11:49 Nikos Alexandris <
> nik at nikosalexandris.net> ha scritto:
>> * Alessandro Sebastiani <alessandro.sebastiani at uniroma1.it> [2018-10-29
>> 21:32:51 +0100]:
>> >thank you all for your suggestions.
>> >Dear Nikos, I have some 0-1 rasters that represents presence-absence of
>> >different land covers. Each raster's resolution is 10x10m, thus i want to
>> >compute the sum in order to obtain the surface covered by each land cover
>> >within my buffers. As regards to the buffer, i want to use the 0-100,
>> >0-200, 0-300, 0-400 and 0-500 for computing stats. I can do it separately
>> >with the module v.rast.stats. I just don't know how to loop it in a
>> python
>> >script
>> Dear Alessandro,
>> I don't have time to write back as I would like. Instead, I will send
>> you off-list some unpublished script.  With a bit of reading, there, you
>> might identify some ideas that will eventually help in what you are
>> doing.
>> Kind regards, Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181031/44035e44/attachment.html>
