[GRASS-user] accent encoding with ps.map
Frank David
frank.david at geophom.fr
Wed Oct 31 03:08:08 PDT 2018
Hello Veronica,
Thanks for your reply. I have seen that note, but it's about the psmap
file encoding standard. What is correct for me (ISO-8859-1), and
[comments] text with accent are well displaying. My problem comes from
data coming from database thru v.label or units as kilometer which comes
from grass translation. please see attached screen-shot.
V.label display well accent in the grass display. but psmap do not
display the same. The only way i see is to remove accent...
Cheers,
Frank
Le 30/10/2018 à 12:03, Veronica Andreo a écrit :
> Hi Frank,
> There's a note on that in the last paragraph under Notes section in
> the manual page [1]
> Vero
> [1] https://grass.osgeo.org/grass74/manuals/ps.map.html
> El mar., 30 oct. 2018 7:33, Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> escribió:
> Hello all,
> I'm using ps.map and I notice that accent are not well supported in 3
> cases :
> - map scale units, for example "kilomètre" is displayed
> "kilomÄ"tre". I
> dont'see how to solve that
> - for a selecting field in vector map, like [where myfield =
> "classé"]
> (does not work) while [where myfield = "classe"] (works if I
> change my
> "é" with "e" in the attribute data). I can solve that by adding an
> other
> field in my table without accent.
> - labels : labels created with v.label seems to cannot support
> accent.
> Is there any way to solve this ?
> my ps.map file are encoded in ISO-8859-1 and other text works well
> with
> accent. I saw that an environment variable exist :
> GRASS_DB_ENCODING but
> I don't know how to see it and if I change if it would damage my data
> table ...
> Is anybody can advice me ?
> I'm using Grass 7.4.1 on debian9
> Thank you for your help,
> Frank
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe autre que texte a été nettoyée...
Nom: CompressedFiles (1).zip
Type: application/zip
Taille: 135523 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181031/40d9b7a6/attachment-0001.zip>
