[GRASS-user] Migrating to new RDBMS
st_kiefer at web.de st_kiefer at web.de
Wed Oct 31 07:31:30 PDT 2018
is it possible to connect to the DB with PGAdmin?
Resp. is remote access enabled?
see
https://blog.bigbinary.com/2016/01/23/configure-postgresql-to-allow-remote-connection.html
https://www.postgresql.org/docs/9.1/static/auth-pg-hba-conf.html
Regards.
Stefan
> Rich Shepard <rshepard at appl-ecosys.com> hat am 31. Oktober 2018 um 14:40 geschrieben:
> On Wed, 31 Oct 2018, Markus Metz wrote:
> > try to set host and port with db.login. Username and password are not
> > required if a ~/.pgpass file exists. See the manual of db.login, following
> > the link to PostgreSQL that describes the GRASS PG driver.
> Markus M,
>    Here ~/.pgpass contains host, port, *, and username. Anyway, I changed
> that line in the script:
> db.login driver=pg database="willamette_river_hg" host='salmo' port=5432
> db.copy from_driver=sqlite from_database="$HOME/data/grassdata/willamette_basin/mercury/sqlite/sqlite.db" from_table=all_species to_driver=pg to_database=willamette_river_hg to_table=all_species_pg
>    The results did not change:
> > $HOME/documents/white-papers/geochemistry/willamette-river-mercury/scripts/grass-to-postgres.sh
> ERROR: DB connection <pg/willamette_river_hg> already exists. Re-run
>         'db.login' with '--overwrite' flag to overwrite existing settings.
> DBMI-PostgreSQL driver error:
> Connection failed.
> FATAL:  database "willamette_river_hg" does not exist
> Connection failed.
>    I think that I've now tried every variation of options with db.login and
> db.connect (which works at the grass shell prompt) with the most current
> releases of 7.7.svn and I'm stymied.
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
