[GRASS-user] Creating elevation for a location
Vidura Dantanarayana
vidurada at gmail.com
Wed Sep 5 10:53:24 PDT 2018
Hi all,
First of all, I must say sorry for my immature question. As I stated before
I am a novice user. It took me a lot of time to find that elevation files
can be directed from the internet. Silly me thought I can create those
files from GRASS GIS itself. Anyways I thank everyone, who spend their time
in solving my problem. Have a nice day.
BR,
On Mon, Sep 3, 2018 at 11:10 AM Vidura Dantanarayana <vidurada at gmail.com>
wrote:
> Hi All,
> Thank you very much for the reply. I will explain what I want to do with
> GRASS GIS. In my university research, I use Wildfire behavior modeling
> module. So in the process, I want to recreate wildfire happened in Los
> Padres National Forest, CA. So following are the things I need to know how
> to do,
> 1) create the map for the location specified.
> 2) generate the elevation raster file from that map.
> 3) generate the aspect raster file from the map.
> 4) generate the aspect slope file from the map.
> I attached some sample files provides by GRASS in the demo data. I need
> these data to run the fire behavior model.
> Have a nice day!!
> BR,
> Vidura Dantanarayana.
> On Fri, Aug 31, 2018 at 1:42 PM Vidura Dantanarayana <vidurada at gmail.com>
> wrote:
>> Hi Rich and Veronica,
>> to do,
>> Have a nice day!!
>> BR,
>> On Thu, Aug 30, 2018 at 6:14 PM Rich Shepard <rshepard at appl-ecosys.com>
>> wrote:
>>> On Thu, 30 Aug 2018, Veronica Andreo wrote:
>>> > It will be easier to help if you provide a more detailed description of
>>> > your problem and what you want to achieve. If what you need is slope
>>> and
>>> > aspect, the module you need is r.slope.aspect. This module needs an
>>> > elevation map as input.
>>> I will add that we need a definition of 'location.' Do you mean one
>>> point
>>> or a defined area such as a drainage basin?
>>> Rich
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180905/f8ef101c/attachment-0001.html>
