[GRASS-user] [GRASS-dev] experimental Python 3 support in trunk
Vaclav Petras wenzeslaus at gmail.com
Wed Sep 5 20:36:41 PDT 2018
On Wed, Sep 5, 2018 at 3:57 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Wed, Sep 5, 2018 at 9:41 PM Martin Landa <landa.martin at gmail.com>
> wrote:
> > Hi,
> > st 5. 9. 2018 v 21:38 odesílatel Markus Metz
> > <markus.metz.giswork at gmail.com> napsal:
> > > alternatively, the shebang in GRASS *.py files can be changed to
> python3 (should be changed to python3 according to Python developer's Guide
> PEP394)
> > we are going to support both Python2 and 3, at least for 7.6/7.8, right?
> Ma
> the symbolic link python is deprecated and will disappear soon from
> current distros: GRASS does not work if python does not exist, while
> python2 and/or python3 might exist. Current distros are already replacing
> the shebang in GRASS *.py files with python2. IMHO, if we want to support
> python3 we need to change the shebang accordingly: no more support for
> python2 in trunk.
> - python as a link to python2 is no longer available on modern distros
> - python3 is older than GRASS7
> - all currently supported distros provide a full python3 environment
Hi Markus and Martin,
That being said, GRASS GIS does not fully support Python 3 yet and, with
exception of few contributions, there was no major work done on the Python
3 support up until recently, i.e. we are not ready to switch to 3 for 7.6.
I think we can have something like "technical preview" in 7.8 (e.g. with
warning "use 3 only if you have to"). 8.0 should fully support 3.
Another thing is that Python 3 means using wxPython 4 to get the GUI (other
wxPythons don't support Python 3). That was hard to do for quite some time
(4.0.0 released in January), but now it is included, e.g., in Ubuntu 18.04
(released April).
As for the shebang, PEP394 says: "for the time being, all distributions
*should* ensure that python, if installed, refers to the same target as
python2, unless the user deliberately overrides this or a virtual
environment is active" and that "python should be used in the shebang line
only for scripts that are source compatible with both Python 2 and 3" which
is what we aim for. So that tells me we should keep there `python` and if a
distro decides to patch it to 2 (because their `python` does not point to
`python2` as PEP394 suggests) or perhaps later to 3 (because they want to
ensure `python3`), they are free to do that. We are not planning to drop
support for 2, so keeping `python` in shebang is appropriate in the long
term according to PEP394.
Best,
Vaclav
Links:
https://wxpython.org/news/wxpython-4.0.0-release/index.html
https://wxpython.org/news/wxpython-4.0.0a1-release/index.html
https://launchpad.net/ubuntu/+source/wxpython4.0
https://www.python.org/dev/peps/pep-0394/
> Markus M
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180905/73ce0c2a/attachment.html>
