[GRASS-user] Help with r.landscape.evol
Nicholas Uwadia uwadianicholas at gmail.com
Tue Sep 11 18:54:49 PDT 2018
Thanks makus for your reply, i have added more details as required and also
the error experienced.
operating system :windows 10
GRASS GIS: 7.4
this is the output command and error
Iteration 1 -- step 4: calculating divergence/difference of sediment
transport for each process and the actual amount of erosion or deposition
in vertical meters/cell/year
Running soft-knee smoothing filter...
Enacting additional "low" smoothing: one pass of a 3x3 modal smoothing
window.
ERROR: Unable to load rules file
<c:\users\samy\appdata\local\temp\grass7-samy-7592\tmpgyoapy>
  File "C:\Users\Samy\AppData\Roaming\GRASS7\addons/scripts/
r.landscape.evol.py", line 681, in <module>
    main(x, (x + 1), prefx, statsout,  region1['nsres'], masterlist);
r.landscape.evol.py", line 509, in main
    grass.run_command('r.colors', quiet = "True", map =netchange, rules =
nccolors.name)
  File "C:\Program Files\GRASS GIS 7.4.0\etc\python\grass\script\core.py",
line 421, in
run_command     return handle_errors(returncode, returncode, args, kwargs)
line 332, in
handle_errors     returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['r.colors', '--q', 'rules=c:\\users\\samy\\appdata\\local\\
temp\\grass7-samy-7592\\tmpgyoapy', 'map=levol_ED_rate']
ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
Thanks
On Tue, Sep 11, 2018 at 10:32 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Sep 9, 2018 at 11:55 PM Nicholas Uwadia
> <uwadianicholas at gmail.com> wrote:
> > hi
> > am trying to model gully erosion changes using the r.landscape.evol  i
> get an erros as the output to excel is blank.  i kindly as if there is any
> tutorial using this tool that can guide me.
> Please post more details - which operating system, which GRASS GIS
> version and which error message appears.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180912/27f8a1f0/attachment.html>
