[GRASS-user] GRASS GIS installation error in ubuntu 16.04
Francesco Pirotti - UNIPD
francesco.pirotti at unipd.it
Wed Sep 12 06:08:06 PDT 2018
It might very well be that you have two versions of proj libraries. Many
gis-related packages drag proj as depency when installed with apt-get
(or other package managers).
Make sure to remove prior proj versions. Also, did you compile the proj
5.1 version? If so after "sudo make install" run the command "sudo ldconfig"
Cheers,
FP
Il 12/09/2018 13:43, Hernán De Angelis ha scritto:
> Hi
> Somehow the installation script does not "see" the libraries. Is your
> library path standard in your system? If not you could add it to your
> ld.so.conf
> Good luck!
> On 9/11/18 2:11 AM, yacob sen wrote:
>> Dear users,
>> I am trying to install the latest version of GRASS GIS from source
>> code in my linux ubuntu 16.04 OS but having difficulty. The error
>> message is as follows:
>> "error while loading shared libraries: *libproj.so.13*: cannot open
>> shared object file: No such file or directory"
>> I have also manually installed the latest version of proj (5.1.0)
>> and provided the library link during configuration of the
>> installation of GRASS GIS
>> clearly both *libproj.so * and *libproj.so.13* do exist in the lib
>> directory of the proj software package and permission is fine.
>> Besides I have soft linked the /usr/lib/*libproj.so* to *libproj.so*
>> The *libproj.so* is resides at my installation directory at
>> /opt/source/proj-5.1.0/build/lib/*libproj.so *and further soft linked
>> to *libproj.so.13*
>> *Any comments please ?*
>> *Regards*
>> *Yacob
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
*FRANCESCO PIROTTI *
*CIRGEO - Interdepartmental Research Center in Geomatics *
*TESAF Department of Land, Environment, Agriculture and Forestry *
*Co-Chair of ISPRS WG III/10 - Agriculture and Natural Ecosystems
Modelling and Monitoring *
Università degli Studi di Padova
Via dell'Università, 16
35020 - Legnaro (PD),Italy
Cell.: +39 392 395 2067
Office.: +39 049 827 2710
Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
Skype: francesco197576 ADD <skype:francesco197576?add>
Web pages: Scholar
<https://scholar.google.it/citations?user=rwgD1BoAAAAJ&hl=en> || Scopus
<https://www.scopus.com/authid/detail.uri?authorId=57198996571>
NOTA CONFIDENZIALE
Ai sensi del D.Lgs. 196/2003 si precisa che le informazioni contenute
nel messaggio e negli eventuali allegati sono riservate al/ai
destinatario/i indicato/i.
Nel caso di erroneo recapito, si chiede cortesemente a chi legge di dare
immediata comunicazione al mittente e di cancellare il presente
messaggio e gli eventuali allegati.
Si invita ad astenersi dall'effettuare: inoltri, copie, distribuzioni e
divulgazioni non autorizzate del presente messaggio e degli eventuali
allegati.
According to Italian law (D.Lgs 196/2003) information contained in this
message and any attachment contained therein is addressed exclusively to
the intended recipient.
If you have received this message in error would you please inform
immediately the sender and delete the message and its attachments.
You are also requested not to make copies, nor to forward the message
and its attachments or disclose their content unless authorised.
Grazie.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180912/8d05c314/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180912/8d05c314/attachment.jpg>
