[GRASS-user] Not matching categories/line IDs
Johannes Radinger
johannesradinger at gmail.com
Thu Sep 13 01:50:15 PDT 2018
Hi all,
I am a little bit puzzled about the actual number of lines/categories of a
specific vector map (river network). As discussed yesterday, the output of
v.category with the report option provides a column 'count' which is a
feature count. Running v.category option=report on my vector provides me
following:
v.category input=Ebro_river_vector_poly_clean_tmp at Ebro2_alien_spread
option=report
Layer/table: 1/Ebro_river_vector_poly_clean_tmp
type count min max
point 0 0 0
line 804 1 1053
This would indicate that I have 804 line features. However, using the tool
v.info on the same vector I get following different result regarding the
number of lines:
v.info map=Ebro_river_vector_poly_clean_tmp at Ebro2_alien_spread
| Number of points: 0 Number of centroids: 0
| Number of lines: 799 Number of boundaries: 0
And even more puzzling, I then added a table to this vector map and the
output of v.db.addtable is:
v.db.addtable map=Ebro_river_vector_poly_clean_tmp at Ebro2_alien_spread
Reading features...
Updating database...
803 categories read from vector map (layer 1)
803 categories read from vector map don't exist in selection from table
803 records updated/inserted (layer 1)
So, is it 804,799 or 803??
The map I am using is a polyline river network (cat=first) that has gone
trough the tool v.clean with the
options: break,rmdupl,rmline,rmsa,rmdangle. The number of lines and cats
before the cleaning tool is 805 (consistent output among all tools).
So I am wondering what happens during cleaning and how to get a clean map
with a corresponding table that has entries for each cat, and were each cat
represents one line feature (i.e. that the number of cats/line features is
consistent over the multiple tools).
Please let me know if I should share the vector map (and how, which format).
Cheers,
Johannes
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180913/3a9797ea/attachment.html>
