[GRASS-user] Not matching categories/line IDs
Johannes Radinger
johannesradinger at gmail.com
Thu Sep 13 23:53:12 PDT 2018
Hi Markus,
Hi all,
I created a zipped version of a test location including one PERMANENT
mapset that includes the vector map that causes these inconsistencies
(Ebro_river_vector_poly_clean_tmp). The test location can be downloaded
from here: https://we.tl/t-eSUZqfP0TQ. I also included the initial vector
map before running the v.clean tool (Ebro_river_vector_poly_tmp). More
specifically, I am using following code:
grass.run_command("v.clean",
overwrite=True,
flags="c",
input="Ebro_river_vector_poly_tmp",
output="Ebro_river_vector_poly_clean_tmp",
tool="break,rmdupl,rmline,rmsa,rmdangle",
threshold="0,0,0,0,0.001")
Maybe this helps to find out what happens here.
/Johannes
On Thu, Sep 13, 2018 at 10:26 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Thu, Sep 13, 2018 at 10:50 AM Johannes Radinger <
> johannesradinger at gmail.com> wrote:
> > Hi all,
> > I am a little bit puzzled about the actual number of lines/categories of
> a specific vector map (river network). As discussed yesterday, the output
> of v.category with the report option provides a column 'count' which is a
> feature count. Running v.category option=report on my vector provides me
> following:
> > v.category input=Ebro_river_vector_poly_clean_tmp at Ebro2_alien_spread
> option=report
> > Layer/table: 1/Ebro_river_vector_poly_clean_tmp
> > type count min max
> > point 0 0 0
> > line 804 1 1053
> > This would indicate that I have 804 line features. However, using the
> tool v.info on the same vector I get following different result regarding
> the number of lines:
> > v.info map=Ebro_river_vector_poly_clean_tmp at Ebro2_alien_spread
> > | Number of points: 0 Number of centroids: 0
> > | Number of lines: 799 Number of boundaries: 0
> > And even more puzzling, I then added a table to this vector map and the
> output of v.db.addtable is:
> > v.db.addtable map=Ebro_river_vector_poly_clean_tmp at Ebro2_alien_spread
> > Reading features...
> > Updating database...
> > 803 categories read from vector map (layer 1)
> > 803 categories read from vector map don't exist in selection from table
> > 803 records updated/inserted (layer 1)
> If there are 804 features, 2 features must have the same category value,
> resulting in 803 updates to the database
> > So, is it 804,799 or 803??
> The output of v.info and v.category option=report must be identical with
> regard to the count of features.
> > The map I am using is a polyline river network (cat=first) that has gone
> trough the tool v.clean with the options:
> break,rmdupl,rmline,rmsa,rmdangle. The number of lines and cats before the
> cleaning tool is 805 (consistent output among all tools).
> > So I am wondering what happens during cleaning and how to get a clean
> map with a corresponding table that has entries for each cat, and were each
> cat represents one line feature (i.e. that the number of cats/line features
> is consistent over the multiple tools).
> > Please let me know if I should share the vector map (and how, which
> format).
> Ideal would be a stripped down GRASS mapset with only this vector
> Ebro_river_vector_poly_clean_tmp. Exporting the vector would change the
> geometry representation and it would no longer be possible to reproduce the
> problem.
> Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180914/1b5fdbe4/attachment.html>
