[GRASS-user] Elevation above a river
Shane Carey
careyshan at gmail.com
Sun Sep 16 10:07:36 PDT 2018
I'm not sure I made myself clear. I have a "real" river vector dataset of
an area.
It includes artificial channels also.
This dataset was digitised manually and does not match the extracted river
dataset from DTM algorithms in grass (r.stream.extraxt)
I need to use the real river vector dataset - hence maybe alter the DTM so
that it picks up these "real" rivers (perhaps by using r.carve?) as opposed
to what would be created by r.stream.extract.
And then when that step is complete, obtain elevation height above the
river.
Hope this makes sense and I am clear in my explanation.
Many thanks all.
On Domh 16 MFómh 2018 at 17:21, Johannes Radinger <
johannesradinger at gmail.com> wrote:
> To me this looks like a flooding-related question, i.e. to extract the
> shore lines of a river if it's water level is raised by 1m or 3m?
> Maybe (1) extract the raster cells of the elevation map that represents
> the river channel, (2) then apply r.grow and (3) then r.mapcalc to subtract
> the grown river channel from the original elevation map.
> /Johannes
> On Sun, Sep 16, 2018 at 5:16 PM Markus Neteler <neteler at osgeo.org> wrote:
>> Hi,
>> Shane Carey <careyshan at gmail.com> schrieb am Fr., 14. Sep. 2018, 23:02:
>>> Hi All,
>>> Does anyone know is it possible to calculate the elevation above a river
>>> channel (actual river network that was digitised as opposed to being
>>> extracted from a DTM) from a DTM and create a polygon from it.
>>> I need to calculate heights of 1m and 3m above a river channel on both
>>> sides of the channel and create a polygon from it.
>> This isn't clear to me. Could you elaborate?
>> Best
>> Markus
>> Thanks all.
>>> Le gach dea ghui,
>>> *Shane Carey*
>>> *GIS and Data Solutions Consultant*
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
Le gach dea ghui,
*Shane Carey*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180916/ce406069/attachment-0001.html>
