[GRASS-user] Raster Attribute Tables
Grace Peixinha
graziaz at gmail.com
Thu Sep 20 20:55:56 PDT 2018
Hi
Try
https://grass.osgeo.org/grass70/manuals/r.category.html
r.category
Grazia
Inviato da iPhone
> Il giorno 20 set 2018, alle ore 22:36, Stefan Blumentrath <Stefan.Blumentrath at nina.no> ha scritto:
> Hi Chris,
> Did you try the table option in r.in.gdal:
> https://grass.osgeo.org/grass74/manuals/r.in.gdal.html
> Otherwise you could import the raster map and then the attribute table with db.in.ogr.
> From the table you could then build reclass rules for r.reclass.
> (Not tested)
> Cheers
> Stefan
> -----Original Message-----
> From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Bartolomei.Chris
> Sent: torsdag 20. september 2018 21:47
> To: grass-dev at lists.osgeo.org; GRASS user list <grass-user at lists.osgeo.org>
> Subject: [GRASS-user] Raster Attribute Tables
> Good evening,
> I'm looking for some way of accessing/using the raster attribute table of some data I have ... unfortunately I suspect it is from Arc. Searching on-line I haven't found anything that points me to GRASS tools to import/read raster attribute tables... Is it supported?
> Here's a sample list of the files I have:
> e008n55_Denmark_0913_texture.tfw
> e008n55_Denmark_0913_texture.tif
> e008n55_Denmark_0913_texture.tif.aux.xml
> e008n55_Denmark_0913_texture.tif.vat.cpg
> e008n55_Denmark_0913_texture.tif.vat.dbf
> e008n55_Denmark_0913_texture.tif.xml
> Thanks
> Chris
> ________________________________
> The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
> The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180921/6ec11015/attachment.html>
