[GRASS-user] Updated trunk to grass77, GUI crashes at start: wxPython/wxWidgets release number mismatch
Hernán De Angelis
dhdeangelis at comhem.se
Sat Sep 22 06:22:19 PDT 2018
Please forget the previous email. I solved the problem by building
wxwidgets from source and then reinstalling grass. All works as expected
now.
/H.
On 9/22/18 2:50 PM, Hernán De Angelis wrote:
> Hi
> I have just updated trunk to grass77 (r73379) via SVN. After the build
> the location selection window opens normally, then, after the location
> is selected, the greeting window flashes normally but the GUI never
> starts. There are a lot of warning/errors (see below).
> I understand that wxwidgets and python may be the culprit. This wasn't
> the case with my previous installation (grass75) although there where
> lots of warnings with this. I have not touched wxwidgets or python
> since my previous grass install.
> Any hint on a solution will be appreciated.
> Thanks in advance.
> /H.
> GRASS 7.7.svn (NVtest):~/NV/grassdb > grass77
> Starting GRASS GIS...
> /usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py:16629:
> UserWarning: wxPython/wxWidgets release number mismatch
> warnings.warn("wxPython/wxWidgets release number mismatch")
> Cleaning up temporary files...
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS GIS 7.7.svn (r72914)
> GRASS GIS homepage: http://grass.osgeo.org
> This version running through: Bash Shell (/bin/bash)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> See citation options with: g.version -x
> If required, restart the GUI with: g.gui wxpython
> When ready to quit enter: exit
> Launching <wxpython> GUI in the background, please wait...
> Traceback (most recent call last):
> File "/usr/local/grass-7.7.svn/gui/wxpython/wxgui.py", line 169, in
> <module>
> sys.exit(main())
> File "/usr/local/grass-7.7.svn/gui/wxpython/wxgui.py", line 156, in
> main
> app = GMApp(workspaceFile)
> File "/usr/local/grass-7.7.svn/gui/wxpython/wxgui.py", line 50, in
> __init__
> wx.App.__init__(self, False)
> File "/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py",
> line 8628, in __init__
> self._BootstrapApp()
> line 8196, in _BootstrapApp
> return _core_.PyApp__BootstrapApp(*args, **kwargs)
> File "/usr/local/grass-7.7.svn/gui/wxpython/wxgui.py", line 101, in
> OnInit
> from lmgr.frame import GMFrame
> File "/usr/local/grass-7.7.svn/gui/wxpython/lmgr/frame.py", line 51,
> in <module>
> from lmgr.layertree import LayerTree, LMIcons
> File "/usr/local/grass-7.7.svn/gui/wxpython/lmgr/layertree.py", line
> 38, in <module>
> from mapdisp.frame import MapFrame
> File "/usr/local/grass-7.7.svn/gui/wxpython/mapdisp/frame.py", line
> 33, in <module>
> from mapdisp.toolbars import MapToolbar, NvizIcons
> File "/usr/local/grass-7.7.svn/gui/wxpython/mapdisp/toolbars.py",
> line 22, in <module>
> from nviz.main import haveNviz
> File "/usr/local/grass-7.7.svn/gui/wxpython/nviz/main.py", line 24,
> in <module>
> from nviz import mapwindow
> File "/usr/local/grass-7.7.svn/gui/wxpython/nviz/mapwindow.py", line
> 42, in <module>
> from nviz.workspace import NvizSettings
> File "/usr/local/grass-7.7.svn/gui/wxpython/nviz/workspace.py", line
> 24, in <module>
> from nviz import wxnviz
> File "/usr/local/grass-7.7.svn/gui/wxpython/nviz/wxnviz.py", line
> 51, in <module>
> from grass.lib.gis import *
> File "/usr/local/grass-7.7.svn/etc/python/grass/lib/gis.py", line
> 988, in <module>
> G_asprintf = _variadic_function(_func,_restype,_argtypes)
> TypeError: __init__() takes exactly 5 arguments (4 given)
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
