[GRASS-user] Updated trunk to grass77, GUI crashes at start: wxPython/wxWidgets release number mismatch
Hernán De Angelis
dhdeangelis at comhem.se
Sun Sep 23 08:42:37 PDT 2018
No worries, thanks for that, Anna.
One question: how do I tell GRASS to use python 3, given that both
Python 2 and 3 are present in the system? I tried using the configure
option "--with-python=/usr/bin/python3" but cannot tell if it worked.
H.
On 9/23/18 1:42 PM, Anna Petrášová wrote:
> Hi,
> trunk is now less 'stable' than usually since it contains experimental
> support for Python 3, but it means there can be new bugs even with
> Python 2 (it was announced on mailing lists). If you want more stable
> environment, please use grass 76, but I will also appreciate you
> testing trunk.
> Anna
> On Sat, Sep 22, 2018, 9:22 AM Hernán De Angelis <dhdeangelis at comhem.se
> <mailto:dhdeangelis at comhem.se>> wrote:
> Please forget the previous email. I solved the problem by building
> wxwidgets from source and then reinstalling grass. All works as
> expected
> now.
> /H.
> On 9/22/18 2:50 PM, Hernán De Angelis wrote:
> > Hi
> > I have just updated trunk to grass77 (r73379) via SVN. After the
> build
> > the location selection window opens normally, then, after the
> location
> > is selected, the greeting window flashes normally but the GUI never
> > starts. There are a lot of warning/errors (see below).
> > I understand that wxwidgets and python may be the culprit. This
> wasn't
> > the case with my previous installation (grass75) although there
> where
> > lots of warnings with this. I have not touched wxwidgets or python
> > since my previous grass install.
> > Any hint on a solution will be appreciated.
> > Thanks in advance.
> > /H.
> > GRASS 7.7.svn (NVtest):~/NV/grassdb > grass77
> > Starting GRASS GIS...
> > /usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py:16629:
> > UserWarning: wxPython/wxWidgets release number mismatch
> > warnings.warn("wxPython/wxWidgets release number mismatch")
> > Cleaning up temporary files...
> > __________ ___ __________ _______________
> > / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> > / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> > / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> > \____/_/ |_/_/ |_/____/____/ \____/___//____/
> > Welcome to GRASS GIS 7.7.svn (r72914)
> > GRASS GIS homepage: http://grass.osgeo.org
> > This version running through: Bash Shell (/bin/bash)
> > Help is available with the command: g.manual -i
> > See the licence terms with: g.version -c
> > See citation options with: g.version -x
> > If required, restart the GUI with: g.gui wxpython
> > When ready to quit enter: exit
> > Launching <wxpython> GUI in the background, please wait...
> > Traceback (most recent call last):
> > File "/usr/local/grass-7.7.svn/gui/wxpython/wxgui.py", line
> 169, in
> > <module>
> > sys.exit(main())
> 156, in
> > main
> > app = GMApp(workspaceFile)
> 50, in
> > __init__
> > wx.App.__init__(self, False)
> > File
> "/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py",
> > line 8628, in __init__
> > self._BootstrapApp()
> > File
> > line 8196, in _BootstrapApp
> > return _core_.PyApp__BootstrapApp(*args, **kwargs)
> 101, in
> > OnInit
> > from lmgr.frame import GMFrame
> > File "/usr/local/grass-7.7.svn/gui/wxpython/lmgr/frame.py",
> line 51,
> > in <module>
> > from lmgr.layertree import LayerTree, LMIcons
> > File
> "/usr/local/grass-7.7.svn/gui/wxpython/lmgr/layertree.py", line
> > 38, in <module>
> > from mapdisp.frame import MapFrame
> > File "/usr/local/grass-7.7.svn/gui/wxpython/mapdisp/frame.py",
> line
> > 33, in <module>
> > from mapdisp.toolbars import MapToolbar, NvizIcons
> > File "/usr/local/grass-7.7.svn/gui/wxpython/mapdisp/toolbars.py",
> > line 22, in <module>
> > from nviz.main import haveNviz
> > File "/usr/local/grass-7.7.svn/gui/wxpython/nviz/main.py",
> line 24,
> > in <module>
> > from nviz import mapwindow
> > File
> "/usr/local/grass-7.7.svn/gui/wxpython/nviz/mapwindow.py", line
> > 42, in <module>
> > from nviz.workspace import NvizSettings
> > File
> "/usr/local/grass-7.7.svn/gui/wxpython/nviz/workspace.py", line
> > 24, in <module>
> > from nviz import wxnviz
> > File "/usr/local/grass-7.7.svn/gui/wxpython/nviz/wxnviz.py", line
> > 51, in <module>
> > from grass.lib.gis import *
> > File "/usr/local/grass-7.7.svn/etc/python/grass/lib/gis.py", line
> > 988, in <module>
> > G_asprintf = _variadic_function(_func,_restype,_argtypes)
> > TypeError: __init__() takes exactly 5 arguments (4 given)
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180923/e520f384/attachment.html>
