[GRASS-user] Import grass.script
Shane Carey careyshan at gmail.com
Sun Apr 7 02:08:31 PDT 2019
Ok thanks, when is it planned to be released? Can you do a pip install with
it?
Thanks
On Domh 7 Aib 2019 at 09:15, Stefan Blumentrath <Stefan.Blumentrath at nina.no>
wrote:
> Hi,
> Python 3 support is planned for GRASS 7.8...
> Furthermore, you might be interested in the grass-session library on
> pypi...
> Cheers,
> Stefan
> *From:* grass-user <grass-user-bounces at lists.osgeo.org> on behalf of
> Shane Carey <careyshan at gmail.com>
> *Sent:* Sunday, April 7, 2019 1:35:11 AM
> *To:* grass-user grass-user
> *Subject:* [GRASS-user] Import grass.script
> Hi,
> I am trying to write an external standalone python script that is using
> grass commands. I setup my variables as below. I then run python3 in the
> terminal and import grass works fine. However, in Pycharm editor, it will
> not import for me. Any ideas of how to get around this?
> Thanks
> export GISBASE="$(grass76 --config path)"
> export PATH="$PATH:$GISBASE/bin:$GISBASE/scripts"
> export DYLD_LIBRARY_PATH="$LD_LIBRARY_PATH:$GISBASE/lib"
> export GIS_LOCK=$$
> export GISRC="$HOME/.grass7/rc"
> export PYTHONPATH="$PYTHONPATH:$GISBASE/etc/python"
> Le gach dea ghui,
> *Shane Carey*
> *GIS and Data Solutions Consultant*
Le gach dea ghui,
*Shane Carey*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190407/c11e7eb0/attachment.html>
