[GRASS-user] Read only mapsets
Panagiotis Mavrogiorgos pmav99 at gmail.com
Fri Apr 26 05:57:26 PDT 2019
On Fri, Apr 26, 2019 at 2:24 PM Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> You could use the PERMANENT mapset for this purpose. Also, the AFAIK
> mapsets are writable by the directory owner. So you could use the
> filesystem setting to achieve what you want to do.
> There is a more detailed explanation here
> https://grasswiki.osgeo.org/wiki/Location_and_Mapsets
> Cheers
Thank you,
Nevertheless, as far as I can tell, the PERMANENT mapset is "readonly" just
by convention. There are no guarantees, that the map will not be changed
during the session.
P.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190426/1f590a63/attachment.html>
