[GRASS-user] Help; Running Grass from R without installing GRASS
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Sun Apr 28 14:17:57 PDT 2019
Hi Mehrdad,
If this is a permission issue, and the dependencies (and a build environment) are installed, you could try compile GRASS (and install it in your home directory if necessary with the --prefix configure option).
svn checkout https://svn.osgeo.org/grass/grass/ grass_trunk
cd grass_trunk
./configure
make
make install
The make install step is not required for starting GRASS though. The make commando creates a bin…/ directory within the grass_trunk dir, where the grass startupscript is located…
Hope that helps.
Cheers,
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Mehrdad Varedi
Sent: søndag 28. april 2019 18:31
To: Micha Silver <tsvibar at gmail.com>
Cc: grass-user <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] Help; Running Grass from R without installing GRASS
Thank you for your time and sharing your knowledge Micha for the second time.
I followed your code and found that initGRASS searches for libraries and binaries of GRASS in gisBase folder. If we address a folder that doesn't have the code it comes back with this error message: "The code execution cannot proceed because libgrass_gis.7.4.1.dll was not found. Reinstalling the program may fix this problem." it gives the same error even if I copy that file into GISBase folder.
I want to run my code on a shiny server which I can't install GRASS although I can copy files and libraries. Can I solve this issue by copying a certain folder of GRASS binaries with my app or I am going the wrong path?
Please advise,
Thank you once again for all the time you share to answer my questions,
Mehrdad
[https://mailfoogae.appspot.com/t?sender=admFyZWRpQGdtYWlsLmNvbQ%3D%3D&type=zerocontent&guid=6036490f-455f-4578-9a0d-ec0122c7134a]ᐧ
On Sun, Apr 28, 2019 at 10:55 AM Micha Silver <tsvibar at gmail.com<mailto:tsvibar at gmail.com>> wrote:
On 27/04/2019 22:05, Mehrdad Varedi wrote:
Hi Everyone,
I have detail explanations of connecting to an existing dataset in GRASS from R in this address: https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7
What I hope I could do is to create a GRASS dataset in R on the fly and without the need to install GRASS or create a dataset on it. Is there any way to do this?
Maybe this will help:
(You must have GRASS installed, of course)
# Parameters for the GRASS installation and temporary GRASS mapset
GISBase = "/usr/lib/grass76"
# Set these as you like
GISDbase = "/tmp"
Location = "tmp_location"
Mapset = "tmp_mapset"
georef = "EPSG:2039"
mapset_path = file.path(GISDbase, Location, Mapset)
# Now run the 'grass' command within R and
# use the -c and -e flags to create the temp mapset, then exit
setup_grass_cmd = paste("grass", "-c", georef, "-e", mapset_path)
system(setup_grass_cmd)
# Load the R grass interface and initialize GRASS within R,
# using the temporary mapset from above
library(rgrass7)
initGRASS(home=tempdir(),
gisBase = GISBase,
gisDbase = GISDbase,
location = Location,
mapset = Mapset,
remove_GISRC = TRUE)
# Try some GRASS commands
input_tif = "isrlat12.tif"
grass_rast = "isrlat12"
execGRASS("r.in.gdal", flags = c("o","overwrite"),
input = input_tif,
output = grass_rast)
execGRASS("g.region", flags="p", raster = grass_rast)
I did not add a command to remove the temporary mapset. Something like:
unlink(file.path(GISDbase, Location), recusive = TRUE) might be necessary
One other note: you probably will get better suggestions on the R-sig-geo list...
i.e. I have a vector /raster file and use that to identify the region and details required to set up a dataset and use GRASS functions just by including rgrass library.
Thanks for your help and attention,
Mehrdad
Mehrdad Varedi
[https://mailfoogae.appspot.com/t?sender=admFyZWRpQGdtYWlsLmNvbQ%3D%3D&type=zerocontent&guid=dbe7ab29-5a21-45c9-97bb-082f4f48224a]ᐧ
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Mehrdad Varedi
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190428/a6ca57e0/attachment.html>
