[GRASS-user] r.grow.distance can't create meters instead of map units
Dimitris sal
jimmaras123 at gmail.com
Fri Aug 2 03:14:19 PDT 2019
Hello
In order to fix it I had to enable the GRASS plugin (is already installed)
then import the raster , and run the plugin's r.grow.distance with geodesic
and it worked.
I just tried this and it worked Thanks for your help!!!
As a local workaround, you can simply search for r.grow.distance.txt
on your computer and add the missing "geodesic" there.
(and open an issue with the QGIS project or open a pull request with
the change there, or someone else does that).
Kind regards
Dimitris
Στις Παρ, 2 Αυγ 2019 στις 12:53 μ.μ., ο/η Markus Neteler <neteler at osgeo.org>
έγραψε:
> Hi Dimitris,
> On Fri, Aug 2, 2019 at 8:58 AM Dimitris sal <jimmaras123 at gmail.com> wrote:
> > Hello everyone
> > My first post in this list,
> > So i am trying to create a raster with r.grow.distance.
> As you are working via QGIS, in which projection do you work?
> > If i use the normal options everything works like the proximity analysis
> of QGIS, but when I try to add the advanced parameter Output distances in
> meters instead of map units i get the error "ERROR: Output distance in
> meters for lat/lon is only possible with 'metric=geodesic'"
> > How do i add in the metrics the geodesic? I only have 4
> euclidean,manhattan,squared,maximum.
> Yes, this is a limitation in QGIS processing (for whatever reason).
> The parameters made available to the QGIS users are often a subset of
> those provided by GRASS GIS.
> # QGIS processing
> grep Metric
> /usr/share/qgis/python/plugins/processing/algs/grass7/description/r.grow.distance.txt
> QgsProcessingParameterEnum|metric|Metric|euclidean;squared;maximum;manhattan|False|0|True
> # GRASS GIS
> r.grow.distance --help
> metric Metric
> options: euclidean,squared,maximum,manhattan,geodesic
> default: euclidean
> The change would be needed here:
> https://github.com/qgis/QGIS/blob/release-3_8/python/plugins/processing/algs/grass7/description/r.grow.distance.txt
> > Is there any alternative to create the raster in meters instead of map
> units?
> Best,
> Markus
> Markus Neteler, PhD
> https://www.mundialis.de - free data with free software
> https://grass.osgeo.org
> https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190802/89209fc6/attachment.html>
