[GRASS-user] Wrangling CityGML with GRASS ?
Markus Metz markus.metz.giswork at gmail.com
Thu Aug 8 06:15:32 PDT 2019
On Thu, Aug 8, 2019 at 2:59 PM "Peter Löwe" <peter.loewe at gmx.de> wrote:
> Hello Markus, Stefan, all,
> thanks for all your advice. New challenges have emerged, as the dataset
is defined as a polyhedral surface:
> I upgraded to GRASS 7.6.1 which comes with GDAL 2.3.1.
> The data sources are official CityGML files provided by the German
Federal Agency for Cartographyand Geodesy (Bundesamt für Kartographie),
which have an ".xml"-extension.
> v.in.ogr -2 -o --o input=TEST.xml output=TEST01
> throws several warnings and creates an empty vector without an
points/lines in it:
>  Warning 1: Unrecognized geometry type : 1015
 [<=== note this!]
> No projection information available for layer <Building>
> Übersteuere die Überprüfung der Projektion.
> Check if OGR layer <Building> contains polygons...
>  100%
> WARNUNG: Vektorkarte <SMALL01> existiert bereits und wird überschrieben.
> Creating attribute table for layer <Building>...
> Importing 1 features (OGR layer <Building>)...
> WARNUNG: Skipping unsupported geometry type 'POLYHEDRALSURFACE'
[<=== note this!]
v.in.ogr could force-convert these polyhedral surfaces to multipolygons, at
the risk of getting garbage.
The required change to v.in.ogr would be small, but it would be safer to
skip these unsupported feature types in order to avoid garbage output.
Markus M
>  100%
> Erstelle Topologie für die Vektorkarte <SMALL01 at PERMANENT>...
> Registriere Primitive...
> WARNUNG: Input data contains 3D features. Created vector is 2D only,
>          disable -2 flag to import 3D vector.
> This problem seems to be ogr/gdal related:
> ogrinfo -al TEST.xml
> describes the geometry as a POLYHEDRALSURFACE Z (((412033.466 5812969.869
> ogr2ogr -f "GML" TEST.gml TEST.xml  fails (some effect when trying other
target formats like CSV or ESRI shape:
> ERROR 6: Unsupported geometry type 3D PolyhedralSurface
> ERROR 1: Export of geometry to GML failed
> ERROR 1: Terminating translation prematurely after failed
> translation of layer Building (use -skipfailures to skip errors)
> There is GDAL documentation about surfaces (
https://gdal.org/development/rfc/rfc64_triangle_polyhedralsurface_tin.html),
but I couldn't find anything about transformations/pruning from 3D to 2D.
> The CGAL library appears to be capable to handle such surfaces, but
GIS-integration seems to be limited (https://www.cgal.org/).
> Ideas on how to proceed, anyone ?
> best,
> Peter
> > Gesendet: Dienstag, 06. August 2019 um 14:46 Uhr
> > Von: grass-user-request at lists.osgeo.org
> > An: grass-user at lists.osgeo.org
> > Betreff: grass-user Digest, Vol 160, Issue 5
> > Send grass-user mailing list submissions to
> > To subscribe or unsubscribe via the World Wide Web, visit
> >       https://lists.osgeo.org/mailman/listinfo/grass-user
> > or, via email, send a message with subject or body 'help' to
> > You can reach the person managing the list at
> >       grass-user-owner at lists.osgeo.org
> > When replying, please edit your Subject line so it is more specific
> > than "Re: Contents of grass-user digest..."
> > Today's Topics:
> >    1. Re: Problems starting grass 7.4.1 in ubuntu (Markus Metz)
> >    2. Re: wms google (Micha Silver)
> >    3. Re: Wrangling CityGML with GRASS ? (Stefan Blumentrath)
> >    4. Re: Wrangling CityGML with GRASS ? (Peter Löwe)
> >    5. Re: Wrangling CityGML with GRASS ? (Markus Metz)
> > Message: 1
> > Date: Mon, 5 Aug 2019 22:32:12 +0200
> > From: Markus Metz <markus.metz.giswork at gmail.com>
> > To: Sebastián Dietrich <sebadietrich at gmail.com>
> > Cc: grass-user <grass-user at lists.osgeo.org>
> > Subject: Re: [GRASS-user] Problems starting grass 7.4.1 in ubuntu
> > Message-ID:
> >       <CAG+h=
FGejQGA8neHu3Sf_hSA6YNSNkOZVDUL1zck8Fk8uM2Gzw at mail.gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > On Mon, Aug 5, 2019 at 5:35 PM Sebastián Dietrich <
> > wrote:
> > > Hi everyone, when i try to launch g.gui i get the following message:
> > > GRASS 7.4.1 (EPSG5344):~/Documentos/grassdata > g.gui
> > > Lanzando GUI <wxpython> en el fondo, por favor espere...
> > > Traceback (most recent call last):
> > >   File "/usr/lib/grass74/gui/wxpython/wxgui.py", line 25, in <module>
> > >     from core import globalvar
> > >   File "/usr/lib/grass74/gui/wxpython/core/globalvar.py", line 39, in
> > <module>
> > >     'locale')).ugettext
> > > AttributeError: 'GNUTranslations' object has no attribute 'ugettext'
> > > [MÁSCARA ráster presente]
> > > Can someone help with this issue?
> > GNUTranslations has an attribute ugettext only in Python2, not in
Python3.
> > Make sure that the link "python" points to "python2", test with "python
> > --version"
> > Markus M
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <
http://lists.osgeo.org/pipermail/grass-user/attachments/20190805/c9190edf/attachment-0001.html
> > Message: 2
> > Date: Tue, 6 Aug 2019 09:19:31 +0300
> > From: Micha Silver <tsvibar at gmail.com>
> > Cc: Ken Mankoff <mankoff at gmail.com>, grass-user at lists.osgeo.org
> > Subject: Re: [GRASS-user] wms google
> > Message-ID: <73c1d605-3729-ab98-2f81-096d4a8d20b7 at gmail.com>
> > URL: <
http://lists.osgeo.org/pipermail/grass-user/attachments/20190806/002e1069/attachment-0001.html
> > Message: 3
> > Date: Tue, 6 Aug 2019 09:13:57 +0000
> > From: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> > To: "Peter Löwe" <peter.loewe at gmx.de>, "grass-user at lists.osgeo.org"
> > Subject: Re: [GRASS-user] Wrangling CityGML with GRASS ?
> > Message-ID:
HE1PR0201MB21405732C039676E8A785D9C9ED50 at HE1PR0201MB2140.eurprd02.prod.outlook.com
> > Hi Peter,
> > Not personally...
> > I would guess you would import CityGML through GDAL:
https://3d.bk.tudelft.nl/svitalis/citygml/gdal/2017/07/24/messing-around-with-citygml-on-gdal-2.2.html
> > There you can create subsets and the like...
> > What are you planning to do with it, roughly?
> > Cheers
> > Stefan
> > -----Original Message-----
> > From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of
"Peter Löwe"
> > Sent: torsdag 1. august 2019 11:10
> > To: grass-user at lists.osgeo.org
> > Subject: [GRASS-user] Wrangling CityGML with GRASS ?
> > Hi list,
> > I'm looking for information/howtos/etc. about how to deal with large
CityGML data sets using GRASS.
> > Has anybody already explored this ?
> > Best,
> > Peter
> > Message: 4
> > Date: Tue, 6 Aug 2019 12:23:29 +0200
> > From: "Peter Löwe" <peter.loewe at gmx.de>
> > To: "Stefan Blumentrath" <Stefan.Blumentrath at nina.no>
> > Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> > Message-ID:
<trinity-c2c845f5-697c-4269-afaf-8be6360d44d9-1565087009741 at 3c-app-gmx-bs34>
> > Content-Type: text/plain; charset=UTF-8
> > Hi Stefan,
> > thanks for the link: That's also the latest information we found so
far, except for several OSGeo conference recordings (e.g.
https://doi.org/10.5446/40913 https://doi.org/10.5446/40694).
> > My colleagues have ingested CityGML datasets into R, which caused
issues with the vector-topology for individual buildings. Also, we have to
cope with significant amounts of CityGML datasets, which would require very
large amounts of RAM, if the processing is done in R. Since GRASS locations
are storage-effective AND GRASS handles vector topologies well, I had hoped
that someone already explored this approach further :-)
> > If this should be not the case (yet) we'll gladly report at one of next
years FOSS4G events.
> > Best,
> > peter
> > > Gesendet: Dienstag, 06. August 2019 um 11:13 Uhr
> > > Von: "Stefan Blumentrath" <Stefan.Blumentrath at nina.no>
> > > An: "Peter Löwe" <peter.loewe at gmx.de>, "grass-user at lists.osgeo.org" <
> > > Betreff: RE: [GRASS-user] Wrangling CityGML with GRASS ?
> > > Hi Peter,
> > > Not personally...
> > > Cheers
> > > Stefan
"Peter Löwe"
> > > Hi list,
> > > Best,
> > > Peter
> > Message: 5
> > Date: Tue, 6 Aug 2019 14:45:50 +0200
> > To: Peter Löwe <peter.loewe at gmx.de>
> > Cc: Stefan Blumentrath <Stefan.Blumentrath at nina.no>,
> > Message-ID:
> >       <CAG+h=
FEkahTTz_DCBcgM8+0GBaqmQ7P_eGLMaEndZigbTdAZ4Q at mail.gmail.com>
> > Hi Peter,
> > On Tue, Aug 6, 2019 at 12:23 PM "Peter Löwe" <peter.loewe at gmx.de> wrote:
> > > Hi Stefan,
far,
> > GML and GMLAS are supported by GDAL 2.2+. However, in order to import
GMLAS
> > properly, some tricks are needed (interleaved reading for non-sequential
> > layers, see
https://gdal.org/drivers/vector/gmlas.html#performance-issues-with-large-multi-layer-gml-files
> > which are built into GRASS 7.6+.
issues
> > That's not related to the data format, but to the content: 3D polygons.
> > These are not supported in GRASS, when importing you need to convert the
> > data to 2D with v.in.ogr -2, otherwise you get corrupt topology. Maybe
this
> > is also needed for R.
> > Markus M
> > > Also, we have to cope with significant amounts of CityGML datasets,
which
> > would require very large amounts of RAM, if the processing is done in R.
> > Since GRASS locations are storage-effective AND GRASS handles vector
> > topologies well, I had hoped that someone already explored this approach
> > further :-)
next
> > > Best,
> > > peter
> > > > Hi Peter,
> > > > Not personally...
> > > > Cheers
> > > > Stefan
> > "Peter Löwe"
> > > > Hi list,
> > > > Best,
> > > > Peter
> > URL: <
http://lists.osgeo.org/pipermail/grass-user/attachments/20190806/2dc10111/attachment.html
> > Subject: Digest Footer
> > End of grass-user Digest, Vol 160, Issue 5
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190808/abb0995c/attachment-0001.html>
