[GRASS-user] wms google
Jonathan Moules jonathan-lists at lightpear.com
Sat Aug 10 12:40:13 PDT 2019
Google maps are not available via WMS, I believe their tiles are only
available via their own proprietary API. I believe QGIS does it because
someone is using that API to make requests (via the QuickMaps Plugin) -
I suspect there's an API Key involved in there somewhere.
You can find OGC services including WMS and WMTS with GeoSeer
(https://www.geoseer.net), but you won't be able to add them to GRASS as
far as I can tell.
If you want raw satellite data without "downloading" you'd want WCS
anyway which I believe GRASS can handle
(https://grasswiki.osgeo.org/wiki/WCS). GeoSeer can help you find those too.
Cheers,
Jonathan
On 2019-08-05 18:54, Sebastián Dietrich wrote:
> Thanks Micha for answering; i want to see satellite images from google
> (or any other server) without downloading them; i.e., connect directly
> to the server and see the images within the grass gis. I can't found
> the way to connect to google server using WMS. I can use this in qgis,
> via xyz tiles (|http://localhost:8080/geoserver)|
> |Thanks!
> On Mon, Aug 5, 2019 at 1:54 PM Micha Silver <tsvibar at gmail.com
> <mailto:tsvibar at gmail.com>> wrote:
>     On 05/08/2019 19:45, Sebastián Dietrich wrote:
>>     Ken, thanks for your answer; but i meant to use xyz tiles in
>>     grass gis, in the manner qgis uses it...
>     Can you clarify what you mean "in the manner qgis uses..."?
>     You can import ASCII xyz files directly, and you can also import
>     point clouds and interpolate a raster surface.
>>     On Mon, Aug 5, 2019 at 1:27 PM Ken Mankoff <mankoff at gmail.com
>>     <mailto:mankoff at gmail.com>> wrote:
>>         On 2019-08-05 at 12:14 -04, Sebastián Dietrich
>>         <sebadietrich at gmail.com <mailto:sebadietrich at gmail.com>> wrote...
>>         > is it possible to load xyz tiles of google images as in qgis?
>>         Yes. See "No plugin required" answer, not accepted answer,
>>         here:
>>         https://gis.stackexchange.com/questions/20191/adding-basemaps-from-google-or-bing-in-qgis
>>         > Did somebody get it work in grass?
>>         I haven't tried yet.
>>         I did just try exporting/saving a Google XYZ layer from QGIS
>>         to my Desktop as a projected GeoTIFF and it did not seem to work.
>>           -k.
>>     _______________________________________________
>>     grass-user mailing list
>>     grass-user at lists.osgeo.org  <mailto:grass-user at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/grass-user
>     Micha Silver
>     Ben Gurion Univ.
>     Sde Boker, Remote Sensing Lab
>     cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190810/450bf42d/attachment.html>
