[GRASS-user] sample a strds at specific locations (areas)
Margherita Di Leo diregola at gmail.com
Wed Aug 14 07:58:47 PDT 2019
Ciao Vero,
indeed that was my first guess about the cause, I double checked but the
region is properly set.
Sorry for late answer, I'm travelling these days with bad to none internet
connection.
Thanks
On Mon, Aug 12, 2019 at 4:23 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Ciao Madi,
> is the region properly set?
> @Stefan in this case, if the centroid only is rasterized, then stats will
> also belong to that pixel only? AFAIU, we don't want that, but stats for
> the area. Or rasterization of centroid would have a different effect?
> best,
> Vero
> El vie., 9 ago. 2019 a las 21:29, Stefan Blumentrath (<
> Stefan.Blumentrath at nina.no>) escribió:
>> Ciao Margherita,
>> This is strange. The area (I assume it is an area though your image just
>> shows the boundary) should definitely get rasterized and thus analysed in
>> v.strds.stats.
>> Can you post the output of:
>> v.category input=big_areas2 at PERMANENT option=report
>> and
>> v.info test -t ?
>> I double-checked, and the possibility to rasterize also centroids is
>> unfortunately not handed down to v.rast.stats (and moduls build ontop of
>> that, like v.strds.stats). This should be done for GRASS version >= 7.6
>> (e.g. by adding centroids to the default selection of types to rasterize in
>> v.to.rast) and is probably worth a ticket.
>> Cheers
>> Stefan
>> *From:* Margherita Di Leo <diregola at gmail.com>
>> *Sent:* fredag 9. august 2019 16:51
>> *To:* Veronica Andreo <veroandreo at gmail.com>
>> *Cc:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>; grass-user <
>> grass-user at lists.osgeo.org>
>> *Subject:* Re: [GRASS-user] sample a strds at specific locations (areas)
>> Hi,
>> excuse me if I return on this. I have again the same problem, of v.strds.stats
>> skipping lots of polygons. Now I'm using a brand new dataset - strds of
>> Sentinel 1 and a brand now vector of polygons - and the skipped polygons
>> are not narrow, I'm sure that there are cells centroids in it. See for
>> example screenshot attached, depicting a polygon that was skipped. I also
>> tried to run v.strds.stats on that polygon alone, like:
>> v.strds.stats in=big_areas2 at PERMANENT where="cat == '1'"
>> strds=db_cross_pol at scaled out=test method=average
>> v.info test
>>  | Mapset:          stats
>>  | Location:        S1
>>  | Database:        /media/madi/TOSHIBA EXT/S1/grassdata
>>  | Title:           Output from v.patch
>>  | Map scale:       1:1
>>  | Name of creator: madi
>>  | Organization:
>>  | Source date:     Fri Aug  9 12:12:49 2019
>>  | Timestamp (first layer): none
>>  | Map format:      native
>>  |   Type of map: vector (level: 2)
>>  |   Number of points:       0               Number of centroids:  0
>>  |   Number of lines:        0               Number of boundaries: 0
>>  |   Number of areas:        0               Number of islands:    0
>>  |   Map is 3D:              No
>>  |   Number of dblinks:      0
>>  |   Projection: UTM (zone 34)
>>  |               N:                 0    S:                 0
>>  |               E:                 0    W:                 0
>>  |   Digitization threshold: 0
>>  |   Comment:
>> I confess I hadn't look much further into it because I thought it was a
>> problem with nodata, but this is not the case and I think it's  worth of
>> further investigation. Thanks for any pointers.
>> Regards,
>> On Thu, Feb 7, 2019 at 4:10 PM Margherita Di Leo <diregola at gmail.com>
>> wrote:
>> Thanks for testing, Vero. I assume it's due to a local problem then.
>> Cheers,
>> On Thu, Feb 7, 2019 at 3:29 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> Hi Stefan and Madi,
>> Thanks Stefan for the explanations :) Indeed I agree that a flag to avoid
>> the alignment to input rasters (and just use region settings) sounds good.
>> I tested what Madi said, but cannot reproduce in the climate NC location
>> [0]. This is the command I used:
>> v.strds.stats in=boundary_county where="cat == '261'" strds=tempmean
>> t_where="start_time >= '2012-01-01'" out=test
>> to make it faster (it feels indeed kinda slow for the whole vector and
>> full time series), I selected only one polygon and a range of dates. I get
>> the table as expected while leaving methods by default.
>> best,
>> Vero
>> [0]
>> http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip
>> El jue., 7 feb. 2019 a las 14:39, Margherita Di Leo (<diregola at gmail.com>)
>> escribió:
>> Thank you Stefan for your help! I figured what happens. v.strds.stats
>> with default method produces in my case a corrupted output, topology is
>> there but there's no table associated to it. If I specify method=average, I
>> do obtain the table, and the mystery is solved: some of the polygons fall
>> into a nodata (due to cloud mask). If anyone else can reproduce the
>> corrupted table issue, I can file a ticket for that.
>> Thanks for help!
>> Regards,
>> On Thu, Feb 7, 2019 at 12:33 PM Stefan Blumentrath <
>> Stefan.Blumentrath at nina.no> wrote:
>> Hi Madi,
>> With this combination (polygon size vs. raster resolution), the shape of
>> the polygons can be an issue (narrow areas that do not cover the center of
>> any pixel).
>> Debugging should be simple with v.db.select or v.extract.
>> Areas that did not get rasterized should be NULL in the column with
>> statistics computed with v.rast.stats.
>> In verbose mode v.rast.stats (or probably even v.to.rast) should probably
>> give a more informative Warning message (e.g. listing categories not
>> rasterized). It also would help if you can rasterize the areas yourself and
>> provide a raster with categories as (optional) input to v.rast.stats…
>> For high resolution data like yours, the speed improvement of multiple
>> raster input might help quite a bit esp. with many maps in the time series.
>> Will see if I can come up with a patch rather soon…
>> Cheers
>> Stefan
>> *Sent:* torsdag 7. februar 2019 10:37
>> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
>> *Cc:* Veronica Andreo <veroandreo at gmail.com>; grass-user <
>> Hi,
>> thank you for your replies. To give a little more context: I selected my
>> polygon areas to be > 0.5 ha each (this would be 50000 mq if I'm not
>> mistaken) and I'm sampling NDVI maps at 10m resolution (the region being
>> the same as NDVI maps). So I think I need an idea on how to debug the areas
>> that were excluded to check them individually to see what could be the
>> problem...
>> Regarding the alignment problem, if I understand it correctly: if the
>> polygon doesn't include the *center* of the raster beneath it, can't
>> retrieve the value and the polygon is discarded? But a value exists, so it
>> would be correct that it returned a value in any case. But I admit I don't
>> have a full grasp of the problem.
>> On Wed, Feb 6, 2019 at 10:52 PM Stefan Blumentrath <
>> Hi Vero,
>> I think there is a little misunderstanding.
>> v.rast.stats did not change it behaviour with regards to the
>> computational region (at least not if only one raster map is used). The
>> alignment to the input raster (resolution) has been around since the module
>> got ported to Python (like 10 years ago):
>> https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.rast.stats/v.rast.stats.py?rev=33522#L148
>> So, adding a flag for skipping the alignment was more an idea for an
>> enhancement that allows the behaviour you seem to prefer (too).
>> Cheers
>> Stefan
>> *From:* Veronica Andreo <veroandreo at gmail.com>
>> *Sent:* onsdag 6. februar 2019 21:38
>> *Cc:* Margherita Di Leo <diregola at gmail.com>; grass-user <
>> I had a similar problem some time ago, just that it was not raster
>> resolution, but region resolution that I changed to solve my problem (see
>> this thread and MM's answer:
>> http://osgeo-org.1560.x6.nabble.com/v-to-rast-for-polygons-not-overlapping-center-of-raster-cell-td5355686.html#a5355729
>> IIUC, MM's proposed solution to my case then does not work anymore
>> because v.to.rast call inside v.rast.stats is affected by the region
>> alignment to the raster to be queried. So, the solution is indeed now, to
>> change raster resolution... ? Then the region would be aligned to it (them)?
>> If one has large areas or long time series and has to resample all
>> rasters to get smallish polygons rasterized, I do not see the advantage of
>> this new behavior... but maybe I'm missing something
>> Cheers,
>> Vero
>> El mié., 6 feb. 2019 16:54, Stefan Blumentrath <
>> Stefan.Blumentrath at nina.no> escribió:
>> Ciao Madi, Vero,
>> Starting with GRASS 7.6, also centroids are used to get the raster
>> representation of your area vector map. That increases the likelihood of
>> smaller areas to be rasterized.
>> Increasing the resolution of the current region alone does not help,
>> because v.rast.stats temporarily changes the computational region to align
>> with the input raster map(s) (see also:
>> https://trac.osgeo.org/grass/ticket/3523 and
>> https://trac.osgeo.org/grass/ticket/3598 for discussion) Even if the
>> first ticket is closed, comments are welcome.
>> It might make sense to add a flag to v.rast.stats like in r.slope.aspect
>> to not align the computational region.
>> Furthermore, with regards to efficiency, v.strds.stats could gain some
>> speed if multi-raster support in v.rast.stats - added in G 7.6 - would be
>> handed down to the addon. Might almost double the speed for larger STRDS…
>> Cheers
>> Stefan
>> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Veronica
>> Andreo
>> *Sent:* onsdag 6. februar 2019 17:20
>> *To:* Margherita Di Leo <diregola at gmail.com>
>> *Cc:* GRASS user list <grass-user at lists.osgeo.org>
>> Hi Madi
>> El mié., 6 feb. 2019 a las 16:31, Margherita Di Leo (<diregola at gmail.com>)
>> escribió:
>> I have a question regarding v.strds.stats. I get the following warning
>> message:
>> WARNING: Not all vector categories converted to raster. Converted 120 of
>> 265.
>> What could be the reason for that?
>> Some vector areas might not be converted because they are too small with
>> respect to the pixel size that you try to query. Others will tell better
>> but I think the polygon must overlap the center of the pixel in order to be
>> converted into raster. One solution could be to resample your rasters to a
>> higher resolution.
>> HTH,
>> Vero
>> Margherita Di Leo
>> Margherita Di Leo
>> Margherita Di Leo
>> Margherita Di Leo
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190814/6f69a70c/attachment-0001.html>
