[GRASS-user] question on Stray light Landsat 8 data
Gabriel Cotlier gabiklm01 at gmail.com
Sun Aug 18 15:05:06 PDT 2019
Hello,
My question is how does it influence the fact that it say:
360 degree EW extent is exceeded by 0.999827 cells
360 degree EW extent is exceeded by 1 cells
[image: image.png]
while when I loaded a first file I defined a region as
[image: Capture.JPG]
which is exactly I suppose the correct region for the DMSP data.... then
after loading the  other layers it appears:
Thanks a lot
Gabriel
On Sun, Aug 18, 2019 at 6:54 PM Gabriel Cotlier <gabiklm01 at gmail.com> wrote:
> Hello, another question, regarding  *i.nightlights.intercalibration, *can
> I run this code as python package/lbrary loading it from Spyder or Jupiter
> Notebook instead of using GRASS interface, if so how is a convenient  way
> to install   *i.nightlights.intercalibration *in python using Spyder?
> Thanks a lot.
> Gabriel
> On Sat, Aug 17, 2019 at 4:54 PM Gabriel Cotlier <gabiklm01 at gmail.com>
> wrote:
>> Dear Nikos.
>> After a long time I'm trying to reproduce a routine I have for doing
>> intercallibratrion of DMSP 1992-2012 but for some reason It doesn't work to
>> me. I think is because the problem between the region of the layers 30 arc
>> sec should resolution be from 0.008333333300000 to 0.008333333333333, i.e.
>> exactly 30 arc-seconds? and the computational region be the same ? I got
>> stuck on how to set it to work... from the side of the region setting.
>> However in addition my routing also has a for loop which does not work ok
>> as well.
>> I would appreciate a lot of you can give it a look and tell me how to
>> make it work...
>> Thanks  a lot in advance
>> Kind regards,
>> Gabriel
>> # complete routine for intercalliration of DSMP/OLS light stable product
>> import grass.script as gscript
>> import os
>> import os,glob
>> # get working directory
>> print os.getcwd()
>> # change working directory where raster files are
>> os.chdir('C:\\Users\\Gabriel\\Documents\\grassdata\\lights')
>> # see files in directory
>> ls
>> # import all raster files to grass --- here is a kind of problem...???
>> for tif_file in glob.glob("*.tif"):
>>     new_rast = os.path.splitext(tif_file)[0]
>>     grass.run_command("r.in.gdal", flags="a", input=tif_file,
>> output=new_rast)
>> # get info of one of the imported raster
>> r.info map=F121996
>> # run intercalliration algorithm
>> image=F101992,F101993,F101994,F121994,F121995,F121996,F121997,F121998,F121999,F141997,F141998,F141999,F142000,F142001,F142002,F142003,F152000,F152001,F152002,F152003,F152004,F152005,F152006,F152007,F162004,F162005,F162006,F162007,F162008,F162009,F182010,F182011,F182012,F182013
>> suffix=c model=elvidge2014 -t
>> # correct general region adjust to raster file --- here the region is
>> exactly 30 arc for the raster as I could see....
>> g.region raster=F121996
>> # cerate a list of rasters in the mapset
>> # rastlist=grass.read_command("g.list",type="rast").split()
>>  rasters = grass.read_command('g.list', type='raster').splitlines()
>> os.chdir('C:\\Users\\Gabriel\\Desktop\\out')
>> # save rasters in mapset to file
>> for raster in rasters:
>>     grass.run_command('r.out.gdal', input=raster, output=raster +
>> '.tiff', format='GTiff')
>> On Wed, Aug 22, 2018 at 10:06 AM Gabriel Cotlier <gabiklm01 at gmail.com>
>> wrote:
>>> Dear Nikos,
>>> Thanks a lot for your answer and the orientation.
>>> The information and the link are very useful.
>>> Kind regards,
>>> Gabriel
>>> On Wed, Aug 22, 2018 at 5:19 AM Nikos Alexandris <
>>> nik at nikosalexandris.net> wrote:
>>>> * Gabriel Cotlier <gabiklm01 at gmail.com> [2018-08-21 12:00:24 -0300]:
>>>> >Dear Nikos and GRASS users,
>>>> >I would like to ask if nonetheless the effect due to "stray light" the
>>>> >*i.landsat8.swlst* code for split window is still applicable to
>>>> Landsat 8
>>>> >data and whether these error is specially visible on water bodies? and
>>>> >whether band 10 is better than band 11 in terms of correction
>>>> processing
>>>> >for Level -1  data products?
>>>> >Thanks a lot.
>>>> >Kind regards,
>>>> >Gabriel
>>>> Dear Gabriel,
>>>> for details and references, refer to
>>>> https://landsat.gsfc.nasa.gov/landsat-8-thermal-data-ghost-free-after-stray-light-exorcism/
>>>> Make sure you use the newest Level-1 Collection 1 Landsat 8 products.
>>>> I use `i.landsat8.swlst` and plan to improve it further.
>>>> However, whether to prefer a Split-Window based approach, or another
>>>> Single-Channel one, depends on what you want to do. Think of spatial
>>>> extent and coverage of various land (cover) types, temporal extent
>>>> and more.
>>>> Thermal remote sensing is hard(er) also because it's hard to get
>>>> ground-truth data sets so as to validate LST estimations.
>>>> Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190818/2f2fc5c9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190818/2f2fc5c9/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190818/2f2fc5c9/attachment-0001.jpe>
