[GRASS-user] question on i.nightlights.intercalibration
Gabriel Cotlier
gabiklm01 at gmail.com
Sun Aug 25 16:13:30 PDT 2019
Dear Markus,
I uninstall and reinstall grass 7.6.1 64 bits and still my log for the
commands
g.region -p
and
g.region -p n=75:00:15N s=65:00:15S w=179:59:45W e=180:00:15E res=00:00:30
are respectively :
(Sun Aug 25 20:01:47 2019)
g.region -p
360 degree EW extent is exceeded by 1.99983 cells
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 75:00:15N
south: 65:00:15S
west: 179:59:45W
east: 180:00:15E
nsres: 0:00:30
ewres: 0:00:30
rows: 16801
cols: 43200
cells: 725803200
(Sun Aug 25 20:01:47 2019) Command finished (0 sec)
(Sun Aug 25 20:02:10 2019)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 75:00:15N
south: 65:00:15S
west: 179:59:45W
east: 180:00:15E
nsres: 0:00:30
ewres: 0:00:30
rows: 16801
cols: 43200
cells: 725803200
(Sun Aug 25 20:02:10 2019) Command finished (0 sec)
Are the resulting intercallibrated layers ready for further use outside
grass exported as GeoTIFF or I need to get inside grass without any
messages that 360 degree EW extent is exceeded for the layer to be OK?
further more I would like to ask if maybe the max and min for
intercallibtated layer are somewhere already available to check whether the
max and min I got are correct?
Thanks a lot for your help.
Regards,
Gabriel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190825/a72ab34b/attachment.html>
