[GRASS-user] error while using i.segment.stats
Veronica Andreo
veroandreo at gmail.com
Mon Dec 2 04:43:30 PST 2019
We are trying to use i.segment.stats for a map with 800000+ segments and
already in two different laptops, we get:
bands=`g.list rast pat=IGUAZU_IMG_* sep=,`
RASTER_STATS=(min,max,range,mean,stddev,median,first_quart,third_quart,perc_90)
AREA_STATS=(area,perimeter,compact_circle,compact_square,fd)
i.segment.stats -rc \
map=segments_full_region \
rasters=$bands \
raster_statistics=$RASTER_STATS \
area_measures=$AREA_STATS \
vectormap=segs_stats_map \
processes=4
Calculating geometry statistics...
Calculating statistics for raster maps...
Exception in thread Thread-3:
File "/usr/lib/python3.6/threading.py", line 916, in _bootstrap_inner
self.run()
File "/usr/lib/python3.6/threading.py", line 864, in run
self._target(*self._args, **self._kwargs)
File "/usr/lib/python3.6/multiprocessing/pool.py", line 463, in
_handle_results
task = get()
File "/usr/lib/python3.6/multiprocessing/connection.py", line 251, in recv
return _ForkingPickler.loads(buf.getbuffer())
TypeError: __init__() missing 3 required positional arguments: 'module',
'code', and 'returncode'
Does it have to do with memory? I used the module a month ago with 500000+
segments and it worked just fine...
Any hints are more than welcome
Best,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191202/3fb1705b/attachment.html>
