[GRASS-user] error while using i.segment.stats
Veronica Andreo veroandreo at gmail.com
Tue Dec 3 04:26:02 PST 2019
Hi Moritz,
Thanks for your answer :)
In smaller subsets (per cutlines tiles), it works just fine.
I will try later today or tomorrow to run it with grass76.
Best,
Vero
El mar., 3 dic. 2019 a las 12:41, Moritz Lennert (<
mlennert at club.worldonline.be>) escribió:
> Hi Vero,
> Le Mon, 2 Dec 2019 13:43:30 +0100,
> Veronica Andreo <veroandreo at gmail.com> a écrit :
> > Hi,
> > We are trying to use i.segment.stats for a map with 800000+ segments
> > and already in two different laptops, we get:
> > bands=`g.list rast pat=IGUAZU_IMG_* sep=,`
> RASTER_STATS=(min,max,range,mean,stddev,median,first_quart,third_quart,perc_90)
> > AREA_STATS=(area,perimeter,compact_circle,compact_square,fd)
> > i.segment.stats -rc \
> >                  map=segments_full_region \
> >                  rasters=$bands \
> >                  raster_statistics=$RASTER_STATS \
> >                  area_measures=$AREA_STATS \
> >                  vectormap=segs_stats_map \
> >                  processes=4
> > Calculating geometry statistics...
> > Calculating statistics for raster maps...
> > Exception in thread Thread-3:
> > Traceback (most recent call last):
> >   File "/usr/lib/python3.6/threading.py", line 916, in
> > _bootstrap_inner self.run()
> >   File "/usr/lib/python3.6/threading.py", line 864, in run
> >     self._target(*self._args, **self._kwargs)
> >   File "/usr/lib/python3.6/multiprocessing/pool.py", line 463, in
> > _handle_results
> >     task = get()
> >   File "/usr/lib/python3.6/multiprocessing/connection.py", line 251,
> > in recv return _ForkingPickler.loads(buf.getbuffer())
> > TypeError: __init__() missing 3 required positional arguments:
> > 'module', 'code', and 'returncode'
> > Does it have to do with memory? I used the module a month ago with
> > 500000+ segments and it worked just fine...
> I don't think memory is the issue, but I find the error message
> pretty cryptic, so wouldn't exclude altogether. Could it be some
> difference between Python 2 and 3 in the multiprocessing module ? Would
> it be possible for you try running it in Python 2 ?
> Maybe you could also try to run it on a smaller subset of the
> segmentation result ?
> Moritz
> Département Géosciences, Environnement et Société Université Libre de
> Bruxelles Bureau: S.DB.6.138
> CP 130/03
> Av. F.D. Roosevelt 50
> 1050 Bruxelles
> Belgique
> tél. + 32 2 650.68.12 / 68.11 (secr.)
> fax  + 32 2 650.68.30
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191203/50f7eb79/attachment.html>
