[GRASS-user] Problem with v.class.mIR
Moritz Lennert mlennert at club.worldonline.be
Wed Dec 4 01:38:40 PST 2019
Sorry for ignoring you up to now, just to much on the platter right now.
Would it be feasible for you to make the data available, privately if
necessary ? The easiest (and lightest) would be just the csv output of
v.db.select on the training_map and the segments_maps.
Moritz
On 2/12/19 16:31, Giuseppe Cillis wrote:
> No one can help me?
> GC
> Il giorno mer 20 nov 2019 alle ore 14:06 Giuseppe Cillis
> <giucillis at gmail.com <mailto:giucillis at gmail.com>> ha scritto:
>     Thanks for the answer._
>     _
>     _
>     _
>     _v.class.mlR segments_map=gbbb at PERMANENT
>     training_map=tainning at PERMANENT train_class_column=fd
>     output_class_column=vote output_prob_column=prob folds=5
>     partitions=10 tunelength=10 weighting_metric=accuracy_
>     _and the same error with this command:
>     _
>     _v.class.mlR segments_map=gbbb training_map=tainning
>     train_class_column=class weighting_mode=smv,swv,qbwwv -i_
>     The vector used was elaborated with i.segment.stats module.
>     An extract is here:
>     cat 	area 	perimeter 	fd
>     1 	958 	208 	1.555034
>     2 	24 	22 	1.945217
>     3 	160 	80 	1.726846
>     4 	2036 	242 	1.440904
>     5 	25 	26 	2.024344
>     6 	222 	96 	1.68966
>     7 	8435 	1012 	1.530879
>     /cat /type Integer (9-0)
>     /fd /type double/real (25-9)
>     For the training area (t/ainning/), I use a simple vector with
>     numerical categories (named/"cate"/) and there are 11 features (just
>     for a trying). The type is in integer64 (10)
>     Il giorno mer 20 nov 2019 alle ore 12:18 Moritz Lennert
>     <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>     ha scritto:
>         On 20/11/19 11:55, Giuseppe Cillis wrote:
>          > Hi,
>          > I'm trying to use this module for classification of an old
>         aerial photos.
>          > After a segmentation (i.segment and i.segment.stats), I would
>         to use a
>          > machine learning approach for the real classification.
>          > I tried with v.class.mIR which use also R.
>          > But there is an error and I don't know how to solve it:
>          > */Durante l'avvio - Warning messages:
>          > 1: Setting LC_CTYPE=it_IT.cp1252 failed
>          > 2: Setting LC_COLLATE=it_IT.cp1252 failed
>          > 3: Setting LC_TIME=it_IT.cp1252 failed
>          > 4: Setting LC_MONETARY=it_IT.cp1252 failed
>          > Carico il pacchetto richiesto: caret
>          > Carico il pacchetto richiesto: lattice
>          > Carico il pacchetto richiesto: ggplot2
>          > Error in `$<-.data.frame`(`*tmp*`, fd, value = integer(0)) :
>          >    replacement has 0 rows, data has 11
>          > Calls: $<- -> $<-.data.frame/*
>          > A part is in italian, I'm sorry.
>          > I'm a beginner in grass and R.
>         R messages are often not very explicit, unfortunately.
>         Could you provide us with the exact command line you use (If you
>         use the
>         GUI, you can get the command line by clicking the 'Copy' button
>         once
>         you've filled out all the parameters, or in the history of the
>         'Console'
>         in the Layer manager.) and an extract of the attribute data you
>         feed
>         into the module ?
>         Moritz
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
