[GRASS-user] SQL: generating numeric class numbers from class text labels?
Hernán De Angelis
dhdeangelis at comhem.se
Wed Dec 4 09:27:53 PST 2019
Hi
I cannot think of a short and simple SQL "one liner" statement but can
think of a short script that will do that using SQL statements.
In pseudo-code, translate to your favorite language:
# get the unique classes
SELECT distinct(label) FROM table;
-> fetch results in an array "txt_label"
# iterate over array and insert new integer labels in table
int_label = 0
foreach txt_label {
INSERT INTO table.label_int VALUES int_label WHERE label = 'txt_label'
n++
This may seem obvious to you, but since you asked :-)
Cheers and good luck
Hernán
On 2019-12-04 18:11, Markus Neteler wrote:
> Hi,
> I have a landuse map with text labels (forest, street, ...). For
> r.learn.ml I need to have them as numeric classes.
> It is not important for me which number is assigned but I search for
> an automated solution, i.e. SQL statement unless there is a different
> way.
> So:
> cat|label|label_int
> 1|forest|1
> 2|forest|1
> 3|street|2
> 4|forest|1
> 5|street|2
> 6|urban|3
> I guess I have done that already some years ago but I can't remember
> the trick :-)
> thanks for a hint,
> Markus
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
