[GRASS-user] SQL: generating numeric class numbers from class text labels?
Moritz Lennert mlennert at club.worldonline.be
Thu Dec 5 00:22:11 PST 2019
On 4/12/19 19:58, Markus Neteler wrote:
> Thanks for your answers.
> In fact I need it in Python...
Using SQL, you can do something like this (SQLite version):
create table mytab (cat int, label varchar, labelint int);
inserts...
select * from mytab;
1|forest|
2|forest|
3|forest|
4|street|
5|street|
6|forest|
7|forest|
8|street|
9|grass|
10|grass|
SELECT cat, label, rank() OVER win FROM mytab WINDOW win as (ORDER BY
label);
1|forest|1
2|forest|1
3|forest|1
6|forest|1
7|forest|1
9|grass|6
10|grass|6
4|street|8
5|street|8
8|street|8
Playing around with that should allow you to feed your table.
Or in pure python:
- get unique labels with v.db.select col=label group=label and put them
in a list
- get numbers with something like this: classnums = [x+1 for x in
range(len(labels))]
- zip the two lists: zip(labels, classnums)
- for each tuple in the list:
	v.db.update col=labelint value=tuple[1] where=label=tuple[0]
Probably there are more elegant solutions.
Moritz
> Micha Silver <tsvibar at gmail.com <mailto:tsvibar at gmail.com>> schrieb am
> Mi., 4. Dez. 2019, 18:57:
>     How about doing this in R? The labels will be read into R as
>     factors, and the factor levels can easily be extracted as numbers.
>     Something like this:
>     micha at tp480:~$ v.info <http://v.info> -c stations
>     Displaying column types/names for database connection of layer <1>:
>     INTEGER|cat
>     INTEGER|station_num
>     TEXT|station_he
>     TEXT|station_en
>     TEXT|type
>     INTEGER|x_coord
>     INTEGER|y_coord
>     DOUBLE PRECISION|long
>     DOUBLE PRECISION|lat
>     INTEGER|elev
>     TEXT|date_open
>     DOUBLE PRECISION|dist
>     DOUBLE PRECISION|azim
>     micha at tp480:~$ R
>     R version 3.5.2 (2018-12-20) -- "Eggshell Igloo"
>     Copyright (C) 2018 The R Foundation for Statistical Computing
>     Platform: x86_64-pc-linux-gnu (64-bit)
>      > library(rgrass7)
>     Loading required package: XML
>     GRASS GIS interface loaded with GRASS version: GRASS 7.6.0 (2019)
>     and location: ITM
>      > use_sf()
>      > stations = readVECT("stations")
>     WARNING: Vector map <stations> is 3D. Use format specific layer creation
>               options (parameter 'lco') to export <in 3D rather than 2D
>               (default).
>     Exporting 94 features...
>       100%
>      > stations['new_station_num'] = as.numeric(stations$station_en)
>      > stations$new_station_num
>       [1] 71 26  6 55 54 63  7  8 31 30 46 84 92 38 32 88 27 12 67 62 47
>     33 53 76 89
>     [26]  2 86 11 40 65 64 45 13 85 60 59  1 74 73 22 19 15 39 50 56 14
>     44 23 36 83
>     [51] 41 42 43 18 17 75 16 82 81 37 48 28 87  3 66 10 34 91 61 93 94
>     72  5  4 68
>     [76] 78 77  9 29 51 58 57 49 52 24 25 80 79 35 70 69 90 21 20
>      > writeVECT(SDF=stations, vname="new_stations")
>     Best regards, Micha
>     On 04/12/2019 19:11, Markus Neteler wrote:
>>     Hi,
>>     I have a landuse map with text labels (forest, street, ...). For
>>     r.learn.ml  <http://r.learn.ml>  I need to have them as numeric classes.
>>     It is not important for me which number is assigned but I search for
>>     an automated solution, i.e. SQL statement unless there is a different
>>     way.
>>     So:
>>     cat|label|label_int
>>     1|forest|1
>>     2|forest|1
>>     3|street|2
>>     4|forest|1
>>     5|street|2
>>     6|urban|3
>>     I guess I have done that already some years ago but I can't remember
>>     the trick :-)
>>     thanks for a hint,
>>     Markus
>>     _______________________________________________
>>     grass-user mailing list
>>     grass-user at lists.osgeo.org  <mailto:grass-user at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/grass-user
>     Micha Silver
>     Ben Gurion Univ.
>     Sde Boker, Remote Sensing Lab
>     cell: +972-523-665918
>     https://orcid.org/0000-0002-1128-1325
