[GRASS-user] S.K. Jenson and J.O. Domingue (1988) method to filter the elevation map
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed Dec 11 05:32:09 PST 2019
I assume you refer to:
https://grass.osgeo.org/grass78/manuals/r.fill.dir.html<https://grass.osgeo.org/grass79/manuals/r.fill.dir.html>
There is also:
https://grass.osgeo.org/grass78/manuals/r.terraflow.html<https://grass.osgeo.org/grass76/manuals/r.terraflow.html>
and
https://grass.osgeo.org/grass76/manuals/addons/r.hydrodem.html
as well as a couple of AddOns based on richdem (starting with r.richdem.*):
https://github.com/OSGeo/grass-addons/tree/master/grass7/raster
[https://avatars2.githubusercontent.com/u/1058467?s=400&v=4]<https://github.com/OSGeo/grass-addons/tree/master/grass7/raster>
grass-addons/grass7/raster at master · OSGeo/grass-addons · GitHub<https://github.com/OSGeo/grass-addons/tree/master/grass7/raster>
You signed in with another tab or window. Reload to refresh your session. You signed out in another tab or window. Reload to refresh your session. to refresh your session.
github.com
Maybe that helps. Can you inform us about the new methods you had in mind?
Cheers
Stefan
GRASS GIS manual: r.hydrodem<https://grass.osgeo.org/grass76/manuals/addons/r.hydrodem.html>
DESCRIPTION r.hydrodem applies hydrological conditioning (sink removal) to a required input elevation map. If the conditioned elevation map is going to be used as input elevation for r.watershed, only small sinks should be removed and the amount of modifications restricted with the mod option. For other modules such as r.terraflow or third-party software, full sink removal is recommended.
grass.osgeo.org
Fra: grass-user <grass-user-bounces at lists.osgeo.org> på vegne av Luis Moreira <lfsmmoreira at gmail.com>
Sendt: onsdag 11. desember 2019 14:16
Til: grass-user at lists.osgeo.org <grass-user at lists.osgeo.org>
Emne: [GRASS-user] S.K. Jenson and J.O. Domingue (1988) method to filter the elevation map
Hello everyone,
I'd like to know if Grass still uses the S.K. Jenson and J.O. Domingue
(1988) method to filter the elevation map, in its original conception. I've
read about some new and more improved methods and was wondering if there
wasn't any improvement in Grass method.
Thank you.
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191211/32a5a389/attachment-0001.html>
