[GRASS-user] error compiling grass 7.8.2 on centos 7
    Markus Metz
    markus.metz.giswork at gmail.com
    Fri Dec 20 00:22:03 PST 2019
On Fri, Dec 20, 2019 at 7:47 AM Laura Poggio <laura.poggio at gmail.com> wrote:
> Dear Markus,
> thanks
> Below my configure (grass 7.6.1 compiles fine with a similar configure.)
> ./configure \
> -prefix=/home/user/grass/ \
is it possible that prefix and path to the GRASS source are identical? This
will not work and cause errors when running "make install". In this case,
prefix must be set to another location, e.g. /home/user/local if you do not
want or can not use the default /usr/local.
Just a guess,
Markus M
> --enable-64bit
--with-fftw-includes=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/include/ \
> --with-fftw-libs=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/lib/ \
--with-freetype-includes=/home/user/grass/freetypes/freetype-2.9.1/include/
> --with-netcdf --with-geos --with-blas --with-lapack --with-postgres \
> --with-zstd-libs=/home/user/grass/zstd/zstd-1.4.0/lib/ \
> --with-zstd-includes=/home/user/grass/zstd/zstd-1.4.0/lib/
> The freetype and zstd are in my home because they are not available on
the cluster, so I had to create them locally.
> If I may, I add an additional question: which is the right option in
configure to point to a specific version of proj? --with-proj-libs?
> Thanks a lot
> Laura
> On Thu, 19 Dec 2019 at 23:36, Markus Neteler <neteler at osgeo.org> wrote:
>> On Thu, Dec 19, 2019 at 8:12 AM Laura Poggio <laura.poggio at gmail.com>
wrote:
>> > Dear list,
>> > I am trying to compile grass 7.8.2 on an HPC cluster using centos 7 as
operative system. I can not install binaries.
>> Just to understand: for policy reasons?
>> > I need to compile from source.
>> > The python version I am using is Python 3.7.4
>> > The configure and the make are working fine.
>> Importantly, pls post your "configure" command to better understand
>> the error below:
>> > However I get the following errors at the make install stage:
>> > rm /home/user/grass//grass78/etc/fontcap
>> > rm: cannot remove ‘/home/user/grass//grass78/etc/fontcap’: No such
file or directory
>> > make[1]: [real-install] Error 1 (ignored)
>> > make /home/user/grass//grass78/etc/fontcap
>> > make[2]: Entering directory `/home/user/grass/grass-7.8.2'
>> > make[2]: *** No rule to make target
`/home/user/grass/grass-7.8.2/dist.x86_64-pc-linux-gnu/etc/fontcap', needed
by `/home/user/grass//grass78/etc/fontcap'.  Stop.
>> > make[2]: Leaving directory `/home/user/grass/grass-7.8.2'
>> > make[1]: *** [real-install] Error 2
>> > make[1]: Leaving directory `/home/user/grass/grass-7.8.2'
>> > make: *** [install] Error 2
>> > Am I missing some dependencies in the fonts?
>> ... probably in the configure step.
>> > Is the python version ok or should I use a slightly older 3.x one?
>> That should be fine.
>> > are there any recommendations for the gcc version to use?
>> No special recommendations.
>> Best wishes
>> Markus
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191220/4854adf7/attachment.html>
