[GRASS-user] Area between drainage networks
Luis Moreira lfsmmoreira at gmail.com
Fri Dec 20 07:40:41 PST 2019
Hello everyone,
I'd like to obtain the area between two drainage networks. The difference
between them is due to different calculation methods.
<http://osgeo-org.1560.x6.nabble.com/file/t385794/photo5181593200849168458.jpg>
The image above illustrates the methodology of mesuring the "error" between
Each one of the drainage networks is in a shapefile, and I need the sum of
all the areas between the segments of the drainage networks, so that I can
mesure the difference between them.
How could I do that with GRASS?
Thanks in advance.
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
