[GRASS-user] sharing GRASS mapsets
Laura Poggio laura.poggio at gmail.com
Wed Feb 6 06:20:45 PST 2019
Hi Stefan,
that helps a lot actually. The suggestion to subdivide the mapset is a good
one. But we also need a way to have more than one person (not all users)
able to manage everything. So probably  the GRASS_SKIP_MAPSET_OWNER_CHECK
is a good option if used carefully.
Thanks a lot
Laura
On Wed, 6 Feb 2019 at 14:47, Stefan Blumentrath <Stefan.Blumentrath at nina.no>
wrote:
> Hi Laura,
> There are several options.
> One option would be to subdivide “ENVIROMENTAL_COVARIATES” into e.g.
> topics.
> In my organisation (also environmental research) we organized mapsets with
> prefixes (g_ for mapsets of general interest, gt_ for time series, p_ for
> projects, u_ for users). Different users can take care of different topics
> (but everybody has to clean up his/her own mess).
> These mapsets can then easily added to the users search_path with
> g.mapsets (https://grass.osgeo.org/grass74/manuals/g.mapsets.html)…
> An advantage of splitting up ENVIROMENTAL_COVARIATES into smaller mapsets
> is that it is easier to move chunks of data (e.g. from central storage to
> compute units (laptop/server))…
> If your users are allowed to change file ownership, they could in
> principle take over “ENVIROMENTAL_COVARIATES”. However, an important
> point of the ownership check implemented in GRASS is to make sure that
> users do not shoot each others in the foot…
> That check can be overwritten with the GRASS_SKIP_MAPSET_OWNER_CHECK
> environment variable (see:
> https://grass.osgeo.org/grass74/manuals/variables.html)
> See also the related issue: https://trac.osgeo.org/grass/ticket/1829
> For both of the latter options there is a significant risk in a multi-user
> environment…
> Hope that helps a bit…
> Cheers
> Stefan
> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Laura
> Poggio
> *Sent:* onsdag 6. februar 2019 12:22
> *To:* GRASS user list <grass-user at lists.osgeo.org>
> *Subject:* [GRASS-user] sharing GRASS mapsets
> Dear all,
> we need to share a GRASS location and its mapsets across multiple users.
> We would like to have a structure similar to this:
> LOCATION:
>  PERMANENT
>  working_mapset_for_each_user
> It is clear in the documentation that a user can only write in a mapset
> that it owns.
> However we would need to have multiple users to be able to
> add/delete/modify files to the ENVIROMENTAL_COVARIATES mapset. Is this
> possible at all? any workaround that can be implemented?
> Thanks in advance
> Laura
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190206/3e01804c/attachment.html>
