[GRASS-user] sample a strds at specific locations (areas)
Veronica Andreo
veroandreo at gmail.com
Wed Feb 6 12:38:06 PST 2019
I had a similar problem some time ago, just that it was not raster
resolution, but region resolution that I changed to solve my problem (see
this thread and MM's answer:
http://osgeo-org.1560.x6.nabble.com/v-to-rast-for-polygons-not-overlapping-center-of-raster-cell-td5355686.html#a5355729
IIUC, MM's proposed solution to my case then does not work anymore because
v.to.rast call inside v.rast.stats is affected by the region alignment to
the raster to be queried. So, the solution is indeed now, to change raster
resolution... ? Then the region would be aligned to it (them)?
If one has large areas or long time series and has to resample all rasters
to get smallish polygons rasterized, I do not see the advantage of this new
behavior... but maybe I'm missing something
Cheers,
Vero
El mié., 6 feb. 2019 16:54, Stefan Blumentrath <Stefan.Blumentrath at nina.no>
escribió:
> Ciao Madi, Vero,
> Starting with GRASS 7.6, also centroids are used to get the raster
> representation of your area vector map. That increases the likelihood of
> smaller areas to be rasterized.
> Increasing the resolution of the current region alone does not help,
> because v.rast.stats temporarily changes the computational region to align
> with the input raster map(s) (see also:
> https://trac.osgeo.org/grass/ticket/3523 and
> https://trac.osgeo.org/grass/ticket/3598 for discussion) Even if the
> first ticket is closed, comments are welcome.
> It might make sense to add a flag to v.rast.stats like in r.slope.aspect
> to not align the computational region.
> Furthermore, with regards to efficiency, v.strds.stats could gain some
> speed if multi-raster support in v.rast.stats - added in G 7.6 - would be
> handed down to the addon. Might almost double the speed for larger STRDS…
> Cheers
> Stefan
> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Veronica
> Andreo
> *Sent:* onsdag 6. februar 2019 17:20
> *To:* Margherita Di Leo <diregola at gmail.com>
> *Cc:* GRASS user list <grass-user at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] sample a strds at specific locations (areas)
> Hi Madi
> El mié., 6 feb. 2019 a las 16:31, Margherita Di Leo (<diregola at gmail.com>)
> escribió:
> I have a question regarding v.strds.stats. I get the following warning
> message:
> WARNING: Not all vector categories converted to raster. Converted 120 of
> 265.
> What could be the reason for that?
> Some vector areas might not be converted because they are too small with
> respect to the pixel size that you try to query. Others will tell better
> but I think the polygon must overlap the center of the pixel in order to be
> converted into raster. One solution could be to resample your rasters to a
> higher resolution.
> HTH,
> Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190206/e5460099/attachment.html>
