[GRASS-user] sample a strds at specific locations (areas)
Margherita Di Leo diregola at gmail.com
Thu Feb 7 07:10:22 PST 2019
Thanks for testing, Vero. I assume it's due to a local problem then.
Cheers,
On Thu, Feb 7, 2019 at 3:29 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi Stefan and Madi,
> Thanks Stefan for the explanations :) Indeed I agree that a flag to avoid
> the alignment to input rasters (and just use region settings) sounds good.
> I tested what Madi said, but cannot reproduce in the climate NC location
> [0]. This is the command I used:
> v.strds.stats in=boundary_county where="cat == '261'" strds=tempmean
> t_where="start_time >= '2012-01-01'" out=test
> to make it faster (it feels indeed kinda slow for the whole vector and
> full time series), I selected only one polygon and a range of dates. I get
> the table as expected while leaving methods by default.
> best,
> Vero
> [0]
> http://courses.ncsu.edu/mea592/common/media/02/nc_climate_spm_2000_2012.zip
> El jue., 7 feb. 2019 a las 14:39, Margherita Di Leo (<diregola at gmail.com>)
> escribió:
>> Thank you Stefan for your help! I figured what happens. v.strds.stats
>> with default method produces in my case a corrupted output, topology is
>> there but there's no table associated to it. If I specify method=average, I
>> do obtain the table, and the mystery is solved: some of the polygons fall
>> into a nodata (due to cloud mask). If anyone else can reproduce the
>> corrupted table issue, I can file a ticket for that.
>> Thanks for help!
>> Regards,
>> On Thu, Feb 7, 2019 at 12:33 PM Stefan Blumentrath <
>> Stefan.Blumentrath at nina.no> wrote:
>>> Hi Madi,
>>> With this combination (polygon size vs. raster resolution), the shape of
>>> the polygons can be an issue (narrow areas that do not cover the center of
>>> any pixel).
>>> Debugging should be simple with v.db.select or v.extract.
>>> Areas that did not get rasterized should be NULL in the column with
>>> statistics computed with v.rast.stats.
>>> In verbose mode v.rast.stats (or probably even v.to.rast) should
>>> probably give a more informative Warning message (e.g. listing categories
>>> not rasterized). It also would help if you can rasterize the areas yourself
>>> and provide a raster with categories as (optional) input to v.rast.stats…
>>> For high resolution data like yours, the speed improvement of multiple
>>> raster input might help quite a bit esp. with many maps in the time series.
>>> Will see if I can come up with a patch rather soon…
>>> Cheers
>>> Stefan
>>> *From:* Margherita Di Leo <diregola at gmail.com>
>>> *Sent:* torsdag 7. februar 2019 10:37
>>> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
>>> *Cc:* Veronica Andreo <veroandreo at gmail.com>; grass-user <
>>> grass-user at lists.osgeo.org>
>>> *Subject:* Re: [GRASS-user] sample a strds at specific locations (areas)
>>> Hi,
>>> thank you for your replies. To give a little more context: I selected my
>>> polygon areas to be > 0.5 ha each (this would be 50000 mq if I'm not
>>> mistaken) and I'm sampling NDVI maps at 10m resolution (the region being
>>> the same as NDVI maps). So I think I need an idea on how to debug the areas
>>> that were excluded to check them individually to see what could be the
>>> problem...
>>> Regarding the alignment problem, if I understand it correctly: if the
>>> polygon doesn't include the *center* of the raster beneath it, can't
>>> retrieve the value and the polygon is discarded? But a value exists, so it
>>> would be correct that it returned a value in any case. But I admit I don't
>>> have a full grasp of the problem.
>>> On Wed, Feb 6, 2019 at 10:52 PM Stefan Blumentrath <
>>> Hi Vero,
>>> I think there is a little misunderstanding.
>>> v.rast.stats did not change it behaviour with regards to the
>>> computational region (at least not if only one raster map is used). The
>>> alignment to the input raster (resolution) has been around since the module
>>> got ported to Python (like 10 years ago):
>>> https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.rast.stats/v.rast.stats.py?rev=33522#L148
>>> So, adding a flag for skipping the alignment was more an idea for an
>>> enhancement that allows the behaviour you seem to prefer (too).
>>> Cheers
>>> Stefan
>>> *From:* Veronica Andreo <veroandreo at gmail.com>
>>> *Sent:* onsdag 6. februar 2019 21:38
>>> *Cc:* Margherita Di Leo <diregola at gmail.com>; grass-user <
>>> I had a similar problem some time ago, just that it was not raster
>>> resolution, but region resolution that I changed to solve my problem (see
>>> this thread and MM's answer:
>>> http://osgeo-org.1560.x6.nabble.com/v-to-rast-for-polygons-not-overlapping-center-of-raster-cell-td5355686.html#a5355729
>>> IIUC, MM's proposed solution to my case then does not work anymore
>>> because v.to.rast call inside v.rast.stats is affected by the region
>>> alignment to the raster to be queried. So, the solution is indeed now, to
>>> change raster resolution... ? Then the region would be aligned to it (them)?
>>> If one has large areas or long time series and has to resample all
>>> rasters to get smallish polygons rasterized, I do not see the advantage of
>>> this new behavior... but maybe I'm missing something
>>> Cheers,
>>> Vero
>>> El mié., 6 feb. 2019 16:54, Stefan Blumentrath <
>>> Stefan.Blumentrath at nina.no> escribió:
>>> Ciao Madi, Vero,
>>> Starting with GRASS 7.6, also centroids are used to get the raster
>>> representation of your area vector map. That increases the likelihood of
>>> smaller areas to be rasterized.
>>> Increasing the resolution of the current region alone does not help,
>>> because v.rast.stats temporarily changes the computational region to align
>>> with the input raster map(s) (see also:
>>> https://trac.osgeo.org/grass/ticket/3523 and
>>> https://trac.osgeo.org/grass/ticket/3598 for discussion) Even if the
>>> first ticket is closed, comments are welcome.
>>> It might make sense to add a flag to v.rast.stats like in r.slope.aspect
>>> to not align the computational region.
>>> Furthermore, with regards to efficiency, v.strds.stats could gain some
>>> speed if multi-raster support in v.rast.stats - added in G 7.6 - would be
>>> handed down to the addon. Might almost double the speed for larger STRDS…
>>> Cheers
>>> Stefan
>>> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of *Veronica
>>> Andreo
>>> *Sent:* onsdag 6. februar 2019 17:20
>>> *To:* Margherita Di Leo <diregola at gmail.com>
>>> *Cc:* GRASS user list <grass-user at lists.osgeo.org>
>>> Hi Madi
>>> El mié., 6 feb. 2019 a las 16:31, Margherita Di Leo (<diregola at gmail.com>)
>>> escribió:
>>> I have a question regarding v.strds.stats. I get the following warning
>>> message:
>>> WARNING: Not all vector categories converted to raster. Converted 120 of
>>> 265.
>>> What could be the reason for that?
>>> Some vector areas might not be converted because they are too small with
>>> respect to the pixel size that you try to query. Others will tell better
>>> but I think the polygon must overlap the center of the pixel in order to be
>>> converted into raster. One solution could be to resample your rasters to a
>>> higher resolution.
>>> HTH,
>>> Vero
>>> Margherita Di Leo
>> Margherita Di Leo
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190207/c207c281/attachment.html>
