[GRASS-user] Adding map to layer manager (wxpython GUI) from grass console?
Joe joe.on.list at gmail.com
Thu Feb 7 08:19:57 PST 2019
On Thu, Feb 7, 2019 at 2:42 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> well, I personally combine both depending on the task on hand. Most of the time, I only use terminal though. When you start learning GRASS, there's a nice feature of the GUI that allows to copy the command once you have set all the options in GUI of that command. Like this you can copy the commands into a text file and then comment and modify there, which allows for reproducibility very easily
> There's a lot of material online that you can follow, for example:
>  - https://gitlab.com/veroandreo/curso-grass-gis-rioiv (links to presentations and exercises in the README)
>  - http://training.gismentors.eu/grass-gis-irsae-winter-course-2018/
Ok Veronica, interesting links, I'll take a closer look at them, thanks again!
Bye!  :D
