[GRASS-user] Unable to read .prj file
Markus Neteler
neteler at osgeo.org
Sat Feb 9 01:51:01 PST 2019
On Fri, Feb 8, 2019 at 11:24 PM Rich Shepard <rshepard at appl-ecosys.com> wrote:
> Environment: Slackware-14.2, Grass 7.7.svn (r74061).
> Trying to create a new location using a shapefile .prj. GRASS tells me it
> cannot read the file using gdal.
I also find that a bit annoying. Indeed, you need to specify the .shp
file and not the .prj file (which doesn't make much sense).
> There are five mapsets I want to import and they all have the same .prj file:
> PROJCS["NAD_1983_UTM_Zone_11N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-117],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
> Do I look for the appropriate EPSG code or am I doing something incorrectly?
Using the "testepsg" script from GDAL I could verify your file:
testepsg bla.prj
Validate Succeeds.
WKT[bla.prj] =
UNIT["Meter",1]]
Simplified WKT[bla.prj] =
UNIT["Meter",1]]
Old Style WKT[bla.prj] =
ESRI'ified WKT[bla.prj] =
UNIT["Meter",1]]
PROJ.4 rendering of [bla.prj] = +proj=utm +zone=11 +ellps=GRS80
+units=m +no_defs
Also GDAL is happy:
gdalsrsinfo bla.prj
PROJ.4 : +proj=utm +zone=11 +datum=NAD83 +units=m +no_defs
OGC WKT :
DATUM["North_American_Datum_1983",
UNIT["Meter",1]]
Just the GRASS GIS logics (still) prevent from accepting a .prj file as input.
Please open a ticket for it, IMHO this should be improved.
(for now use the .shp file)
Markus
