[GRASS-user] get the shifted minimum from a raster series
    Frank David
    frank.david at geophom.fr
    Sat Feb 16 02:00:54 PST 2019
Hi Micha,
Thank you for your email. Your script is very interesting, but I think I
cannot use it because:
1- you make a sum of your viewshed list, and each viewshed value is 0 or
1 (hidden or visible). But my problem is with viewshed values from 0
upto 250 (for each viewshed this is the hidden height from a viewpoint).
So make a sum has no sens.
2- you search the pourcent of visible terrain from all viewpoints, and I
want find pourcent of viewpoints able to see terrain (actually to not
see the maximum hidden height above terrain)
Tell me if I'm wrong...
I wrote a script with garray.array() which read the value for each
specific x,y cell coordinates from all viewshed rasters, create a list
of data, sort that list, and get the shifted min (according to my
tolerance, for example 80% of 100 viewpoints get the twentieth smallest
value). In that way Each cell of my output raster give the hidden height
from 80% of my viewpoints. The script is working, but I believe that
adding this function in r.series could be useful.
Cheers,
Frank
Le 15/02/2019 à 15:52, Micha Silver a écrit :
> Hello Frank:
> On 2/7/19 3:16 PM, Frank David wrote:
>> I forgot one thing to well understand my wish. Each viewshed raster
>> is a r.series (250-sum) of 250 r.viewshed with 2m target and 0 upto
>> 250m terrain height. So each raster gives the hidden height of a
>> building (250m max) anywhere on the region from a specific point of
>> view. The purpose is to get the area of hidden wind turbine from
>> roads for a specific wind turbine height.
>> Cheers,
>> Frank
> A friend and I were working on an idea some months ago that might be
> of interest. Not the same as your project but the method I used is
> similar.
> The search and rescue teams here are interested to see what areas were
> actually visible after they finish searching along a certain route,
> and what areas were not seen at all. I used the same approach as you,
> creating a series of overlapping r.viewshed intermediate rasters.
> After seeing your post, I have added new input parameters for minimum
> and maximum values of overlap. The user can enter percents of minimum
> or maximum viewshed overlaps. Suppose I put in 20 as the minimum, then
> only those pixels with at least 20% of the total number of viewsheds
> will be shown. Similarly, if I enter 80 as the maximum, then only
> those pixels with less than 80% of the maximum number of viewsheds
> will appear in the final raster.
> If you are on Gitlab, you can clone the files: No documentation yet :-(
> https://gitlab.com/tsvibar/route_viewshed
> If you do adopt any of this script, I'd appreciate to hear of any bugs
> or suggestions for improvement. If the script raises any interest,
> I'll add it to the Addons.
> Regards,
> Micha
>> Le 07/02/2019 à 12:48, Frank David a écrit :
>>> Hi,
>>> Thanks for your reply. I can have numerous raster (several
>>> hundreds). I want to find a minimum but with a tolerance, it's why I
>>> want to be able to shift the value. In fact I want to sort the value
>>> of my all input raster for each x,y cell and get the second or
>>> third, or any position in the sorted list, to build my output
>>> raster. My application is to get the area not visible from a road (I
>>> did 1600 viewshed raster from the roads every 250m). I want a
>>> tolerance in order that one point of view (top of hill) does not
>>> reduce too much the hidden area. To do so, a fixed number of my
>>> point of view (20%) does not reduce the hidden area. The result is
>>> the area is hidden from 80% of the road.
>>> I already wrote a python script that read all rasters for each x,y
>>> cell and make a array(), sort the array values, and build a raster.
>>> It works on reasonable number of cell, but seems to fails with large
>>> number of cells. I'm not a programmer !
>>> I wondered if this kind of treatment exists already in Grass.
>>> If somebody wants to hemps me to develop this, I could be nice. But
>>> I think it could be an improvement of r.series function.
>>> Sorry for my bad english, I hope you have understand my wishes !
>>> Cheers
>>> Frank
>>> Le 07/02/2019 à 12:04, Veronica Andreo a écrit :
>>>> Hi Ken,
>>>> There isn't any build-in function for that in grass, afaik.
>>>> Depending on how long is your series, you could shift the map list
>>>> you use in each run and then use r.univar on each output from
>>>> r.series to get the minimum and by comparison, get the second
>>>> minimum of the series of maps (a scalar).
>>>> However, if what you need is a map of second minimums per pixel, I
>>>> believe that might require some programming for a new function...
>>>> Do you know any other software which has this function? Maybe, if
>>>> there's such thing in Python for example, it could be recycled or
>>>> used with grass maps in a script... Dunno, just thinking out loud
>>>> best,
>>>> Vero
>>>> El jue., 7 feb. 2019 07:16, Ken Mankoff <mankoff at gmail.com
>>>> <mailto:mankoff at gmail.com>> escribió:
>>>>     Hi Frank,
>>>>     On 2019-02-07 at 08:27 +0100, Frank David
>>>>     <frank.david at geophom.fr <mailto:frank.david at geophom.fr>>
>>>>     wrote...
>>>>     > I try to find how to get the shifted minimum value of a series of
>>>>     > raster map. I want to shift by one, or more, the "minimum"
>>>>     value found
>>>>     > on each cell to get the "almost minimum" of the series. Is
>>>>     there an
>>>>     > available function/method to do that ?
>>>>     I don't think I fully understand what you want. Are you working
>>>>     with strds? You mention "series". If I wanted to get the
>>>>     second-minimum of a single raster, I would use r.stats with the
>>>>     "-1" flag, sort, and search for the 2nd (or 2nd-to-last).
>>>>       -k.
>>>>     _______________________________________________
>>>>     grass-user mailing list
>>>>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>>>     https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ.
> Sde Boker, Remote Sensing Lab
> cell: +972-523-665918
*Geophom*
327 rue de Vieille Cour 44521 OUDON
Tel +33(0)2 85 52 02 59 - Port +33(0)6 04 47 91 06
www.geophom.fr
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190216/0d86a34f/attachment-0001.html>
